Question about GE (PSS26MSRSS) Side by Side Refrigerator
Mitsubishi MR 560X. Top shelf of freezer not freezing food. Vents have been icing up. Fridge appears to be running too warm, around 11degrees Celsius. I have turned off fridge and defrosted it for 24 hours. Checked door seals ok. Problem unresolved. Any ideas?
  • GE Master
  • 842 Answers
You have lot your evaporator fan motor in the freezer that caused no air to circulate, this would also effect the refer section too. P# WR60X10185 if you need it, check to see if the fan remains running on high speed even when the freezer door is open for 3-5 minutes.
Good Luck
Posted on Dec 26, 2013
SOURCE: GE Bottom-Mount No-Frost Refrigerator
check the evaporator drain.
Posted on Sep 28, 2008
kachbibi1
  • 979 Answers
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Posted on Jan 14, 2009
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Compressor not running, Fridge/Freezer not
Unplug refrigerator pull away from wall. Remove cover over compressor and feel top of compressor to see if overheating or trying to start. If too hot to hold hand on top leave unplugged until we locate the problem. This could be capacitor, start relay, overload, motherboard. This can Be fixed but we need to eliminate cause before replacing any parts. Sea Breeze
Posted on Jan 23, 2010
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
