Question about Autocraft TOOL 2-1/4 Ton Hydraulic Trolley Jack - AC940/T82253
Operating instructions for 2.5 ton autocrat lift
How much can my lever ratchet hoist lift?
Common ratchet lever hoists have the capasity to lift up to 5 tons, but some can only lift 1/2 ton its important to consult your user manual for exact numbers before use.
Nov 21, 2013 | Hoisting
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
I don't get this product. How does it work?
You purchased jack stands, they aren't intended to lift the car, merely to support them after you've raised the car with a jack.
Apr 30, 2013 | Torin Big Red Torin Double-Locking Ratchet...
What size floor jack do I need for a 1987 toyota camry?
Any roll away floor jack from a autoparts store will be fine and strong enough
Mar 04, 2013 | 1987 Toyota Camry
Firing order and timing count
1991 Ford Truck F150 1/2 ton P/U 2WD 4.9L FI 6cyl Firing order 1-5-3-6-2-4 10 Degrees 1991 Ford Truck F150 1/2 ton P/U 2WD 5.8L FI Windsor 8cyl Firing order 1-3-7-2-6-5-4-8 10 Degrees 1991 Ford Truck F150 1/2 ton P/U 2WD 5.0L FI 8cyl Firing order 1-5-4-2-6-3-7-8 10 Degrees
Jun 03, 2009 | 1991 Ford F150
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Autocraft TOOL 2-1/4 Ton Hydraulic Trolley Jack - AC940/T82253 Logo
159 people viewed this question
Top Autocraft TOOL Hoisting Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Are you an Autocraft TOOL Hoisting Expert? Answer questions, earn points and help others
