Question about Intel Motherboard
P4SDR-VM SiS650/GL Motherboard
I need to know where to connect the power supply swith and the other small connectors.
Can you help
Richard.curret@yahoo.co.uk
I need SIS650/GL Mother Board Circuit Diagrams Can u proviedmeplease
Posted on Apr 29, 2009
Vbhvb
Posted on Mar 26, 2008
  • 51 Answers
I didn't quite get this. But if you are asking about the position of a switch that is located on many power supplies these days, then here it is. You should set the switch matching the power specifications of your country. So if your country provides 110V supply, switch it to that voltage. If not, switch it to the other side.
Here is a pointer on how to connect the pins to various devices in your computer:
http://www.fonerbooks.com/r_power.htm
Posted on Oct 18, 2007
SOURCE:
What PSU
The initialism PSU often refers to a Power supply unit, or specifically a computer'sPower supply unit (computer).
Aug 05, 2012 | ASUS P5S800-VM Motherboard
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
How to connect power supply to p5pe -vm motherboard
There are two power connectors required from an ATX switch mode power supply.
A 20 pin ATXPWR connector and
a 4 pin 12 volt ATX12V connector
If you want a copy of this motherboard manual , please click on this link to download a copy :-
http://www.manualnguide.com/dl/9172/
Oct 09, 2010 | ASUS P5PE-VM Motherboard
Need to upgrade Alienware PC with P5GD1-VM
You need 24 connection power supply 500 watt
Apr 29, 2010 | ASUS P5GD1-VM Motherboard
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
WITH INTEL PROCESSSOR .I NEED VGA DRIVER
Please let us know the complete model number of the motherboard and the operating system of your computer.
Thanks for using FixYa.
Feb 25, 2010 | Computers & Internet
Asus A8N-VM CSM wont boot, no fans come on or anything, green light comes on the motherboard, is the CPU dead? tried different ram still the same. any help would be great!
CHECK ALL JUMPER ON THE BOARD AND MAKE SURE THE BOIS RESET JUMPER IS ON JUMPER 1-2, SOUND LIKE A POWER SUPPLY PROBLEM NOT ENOUGH WATT TO RUN THE SYSTEM
2ND OPTION, REMOVE ALL WIRE AND ADDTIONAL CARDS, MIN. MEMORY, LEAVING 1 STICK OF RAM, VEDOI CONNECTION , AND THE POWER TO THE BOARD, CONNECT ONE WIRE AT A TIME AND RESTARTING THE MACHINE EVERY TIME UNTIL YOU FIND THE PROBLEM.
CANDYMANGANDY
Feb 05, 2009 | ASUS A8N-VM CSM (00610839133826)...
ASUS motherboard driver
Try this link
http://support.asus.com/download/download.aspx?modelname=P4SDR-VM&SLanguage=en-us
I hope it helps!!!
Nov 27, 2008 | Computers & Internet
Motherboard trouble shooting
Double check all your case connectors to the motherboard. Use a strong flash light so you can see the markings on the board. All connectors, connect left to right. Check the back of the power supply make sure the red switch is set to 115V. Clear the cmos. Use your manual & find the bios jumper. If you haven't a clue than just remove the battery. Make sure you unplug the power cord from the power supply first. Replace the battery & boot the system. Pay attention to the fan on the cpu, case lights & CD/DVD lights. If you put this system together your self & it is your 1st time please let me know. There could be many other items that will need to be checked before you make too big of a boo boo & kill the board.....
Jan 15, 2008 | ASUS P4S333-VM Motherboard
MOTHER BOARD DRIVERS
You should be able to download drivers and other software or firmware for your motherboard if you go to http://support.asus.com and click Downloads.
On the upper left of your window, enter "P4SDR-VM" as the search term, and select "Drivers" in the drop down menu below it. Click the search button, and you should find results for your motherboard.
Jan 14, 2008 | Intel P4 System Configurator (P4SDRAM1) PC...
Intel Motherboard Logo
436 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
