Question about Quasar HQ2051TH Air Conditioner
Noice comming when we start the fan
Every time that i start the fan or cool the vent is making a lot of noice i think i need to ope and see if something is obstructing it does anyone have a manual or some instructions of what to check in my Quasar HQ2102DW
  • Jason vangel May 11, 2010
    could you describe the noise is it a rattling noise or high pitch
2 Suggested Answers
lsteward68
  • 331 Answers
SOURCE: Won Quasar TV Model W-2009 (I think that's right
Hi Mel is the manual all you need or do you have a specific question.
thank you
Ray
Posted on Dec 28, 2009
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Apr 21, 2014 | TurboChef TORNADO Electric Oven
When i start games on my pc the temperature increased to 100 degrees and pc turned off.
First, and most importantly: don't attempt to run any more graphics-intensive applications on your notebook (such as games) until you resolve the problem; you can permanently damage your computer's internal hardware.
There a couple reasons computers will overheat:
  • As it appears you're using a laptop, make sure you use it on a smooth, flat surface. Placing on surfaces like bedding or carpet can block the exhaust vents on the machine, causing heat to build up inside the chassis.
  • Look at the exhaust vents on your laptop: is there a lot of visible dust and dirt in them? Your vents (and the internal cooling fan) are probably clogged. A can of compressed air can help to blow debris out. If there's a lot of debris compacted in the vent or fan, though, you may need to have the machine taken apart to physically remove the blockage.
  • Finally, listen to your machine: do you hear the fan come on at all? If your fan never spins up, you may have a faulty fan. In this case, there is not sufficient airflow to cool your system, and you'll need to have the fan replaced by a certified technician.
Mar 03, 2011 | ASUS K50AF Notebook
I have a powersuppliefan that make a lot of noice. My question is: is it possible to replace the fan with a new and more quiet on? I have a zepto d47v
You can replace the fan. Most are 120mm at 120VAC. I would advise against it unless you know what you are doing. Power supplies can carry a charge even though they are disconnected. Better off replacing the power supply.
Oct 28, 2010 | Sharp Computers & Internet
The draft inducer comes on and the furnace lites as normanl Goes thru its cycle and kicks off. The problems is the draft may not kick on the next time and sticks and the motor gets hot, If I go remove the...
When a furnace is replaced with a newer style unit like yours with an inducer motor, they sometimes use the old vent pipe. These old style vent pipes are transite (light weight cement), the moisture created from your furnace exhaust is caught on the cool transite surface and runs back down into the blower blades or wheel bringing a white mineral deposit with it which causes your problem. The vent should nave been replaced with the heater using a metal vent material. You will need to replace your inducer motor assembly and vent pipe to prevent a recurrence.
Dec 04, 2009 | Omega Trane Furnace Draft Inducer Blower...
SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Jun 24, 2009 | Sony Computers & Internet
Lazer 73: blower making a lot of noice
G M,
Your stove does need to be overhauled. The vibrations are the blower exhaust wheel being out of balance due to carbon build up. If it has been vibrating for a long time you will need to replace the motor. The L73 motor bearings are hard to get off without either bending the shaft or breaking the rev sensor. The burner pot will be another part that may need changing. It may have a warped or cracked bottom. If this is so it needs to be replaced with a new one. The burner ring will have to be replaced as will the mat. Several gaskets will need to be on hand in case you break them. All toll the above will run around $400 or so. It's well worth it considering a new one is $1750 or so. The first thing you need; though, is a service manual. Get in touch with your local dealer and get one. It will make your repair much easier.
Tom Hawkins
hawkins111@gci.net
Feb 26, 2009 | Rinnai Toyostove Direct Vent Heater:...
GE Spacemake XL1800 whines every time it cooks works great the
The charcoal filter must be changed every 6-12 months, depending on how much and how the oven is used.
If a filter clogs, it will interfere with cooling and lead to magnetron damage.
It may also be putting a strain on the cooling fan or hood vent exhaust fan, or one of those fans may have a blade loose on the motor shaft.
You can usually find helpful exploded view diagrams and order parts (including filters) by entering your full model number here.
Dec 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Compaq Presario SR1365CL (4) yrs old, fan making annoying noice
Often you can blow the dust out of the fans and it will help. In your case the bearings have most likely dried up on a fan. First blow the dust out of all the fans. To find the offending fan you will have to block the blades with something. Once the fan is found you can either replace it with a fan of the same size or re-oil the bearings. To re-oil, carefully peal away the label on the fan. There might be a plastic plug over the bearing, carefully remove it. Drop a few drops of 4-in-1 oil or sewing machine oil into the bearing. Stick the label back on and put the fan back into the system. It should be much quieter now.
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
PC Fan
it's difficult but what about water cooling.?
or try check zalman homesite
http://www.zalman.co.kr/eng/main.asp
they make noiceless cooling systems.
May 15, 2008 | Dell Precision 380 P4 Dual Core 3 GHz...
Intel p4 3.0ghz with 800fsb fan makes more noice
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Aug 16, 2006 | Intel Pentium 4 630, 3.0 GHz...
Quasar HQ2051TH Air Conditioner Logo
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
