Question about Ubi Soft Tom Clancy's HAWX for Windows
Save dump file to hawx.exe.dmp - Ubi Soft Tom Clancy's HAWX for Windows
What is RAID? Can this cause video issues? Can the Video problems be ralated to the PSU?
RAID is where you use data in stripes over many disks to improve reliability, one disk can go down and can be replaced without rebuilding machine. RAID is not appropriate for a single disk machine.
Jun 23, 2014 | Dell Dimension 8100 PC Desktop
Tip
D-Link DMP-90 16 MB MP3 Player Tips
I hope this helps the many people searching for drivers for this digital music player...First one should completely read the DMP-90 USERS GUIDE,SPECIFICLY the Appendage....I wonder if this is a major reason why users cannot get the MP3 player to work ??? If it simply does not connect to ones computer ...... the reason will be that the Parallel Port Mode is incorrectly set...So how do we check this ? First click START &gt; then Right Click My Computer &gt; then Properties .&gt;then Hardware &gt; then Device Manager ......<br /><img src="hairy_kiore_4.gif" /><br />Now Expand + on Ports (Com & LPT)<br /><br /><img src="hairy_kiore_0.gif" /><br />If it does not state ECP Printer Port the DMP-90 will not have a connection with the computer...<br />So lets say it only reads Printer port (with no ECP in front of it) ...Well one has to set this within the bios of ones computer.. So if one does not know how to do this get a friend who does ....<br />Now the drivers ...That work with XP..Heres the link..<br />http://drivers.downloadroute.com/D-Link-DMP-90-Mp3-Manager-041502.html<br />and the file name....<br />Dlinkdmp90_app_041502.exe<br /><img src="hairy_kiore_2.gif" /><br /><br />Install in Folder.....It will have 3 files...<br /><img src="hairy_kiore_3.gif" /><br />Open Readme text file and read it....It basicly says ...Execute the port95nt.exe program first. It will automatically upgrade your Win2000/NT/XP with the new patches. then reboot your computer..then one can move the cakernt.exe file into another directory or folder ....then Double click the cakernt.exe and it will activate the program for downloading the MP3 files into the player.....I actually never moved the cakernt.exe..I just double clicked it from its install folder and dragged the MP3's into it.......<br /><br /><br /><br />
on Nov 04, 2010 | Audio Players & Recorders
Missing C:\Windows\Minidump\122513-59685-01.dmp
probably dump file was deleted or dump file creation was interrupted , reason for a missing file or an empty file name.Another file of the same nature may be created again if the same blue screen message appears again for the same problem.
Dec 25, 2013 | Computers & Internet
Memory dump error
Kindly start windows in safe mode by pressing F8 key while powering up, Goto device manager and uninstall any new installed drivers or device.
Regards,
Kaushik Patel
Sep 13, 2013 | Dell PowerEdge Computers & Internet
WHAT OR WHERE IS THIS? C:\Docume~1\OwnerLocals~1\Temp\Picasa110828-211727.dmp
This is supposed to be a dump file, If you press the Windows key and while holding it press R, The run menu should show up, (the win key is between ctrl and alt on most keyboards, it has a flag typically)
Paste this into the run menu
C:\Documents and settings\Owner\Local settings\Temp\
You will be looking for the file
Is it showing up in your virus scan or something? If you still cannot see the file, but know its there, Click Tools > Folder Options, Select Show all hidden files, and Uncheck the Hide operating system files (about 2 options lower), Click ok and you should be able to see it if it is there.
Aug 29, 2011 | Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Dec 23, 2010 | Computers & Internet
Ubi Soft Tom Clancy's HAWX for Windows Logo
161 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
Hanzu
dante
Tom Chichester
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
