Question about Uniden Cordless Phone
I have uniden power max 5.8ghz portable phone,how do I remove all incomming calls
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden PowerMax 5.8GHz phone, I can only suggest you select it from the list beginning at http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=cordlessphones_mnl to download a copy of the manual.
Posted on Dec 25, 2013
chris5563
  • 37 Answers
SOURCE: uniden tru8880-2hs
In standby mode, press the volume "up" key or volume
"down" key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Posted on Nov 07, 2007
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
Have a uniden 5.8... The problem is incoming calls do not ring. Outgoing calls work perfectly. The caller hears one ring and then their phone goes silent.
You have probably accidentally activated a blocking function on your phone! Take the portable handset, and remove the battery. Wait five minutes, then reconnect the battery. That should reset the phone to "initial conditions," which are the settings it had when it was new.
Apr 17, 2017 | Uniden Lands Phones
How do I erase all incoming calls on uniden powermax5,8gh portable phones
Dec 25, 2013 | Kitchen Appliances - Others
I have a uniden power max 5.8ghz phone and can't turn on the ringer it will not ring when a call is incoming how do I turn on the ringer ?
The procedure varies from model to model. Since you neglected to specify the model of your Uniden Powermax 5.8GHz cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 30, 2011 | Uniden Cordless Phone
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
Jan 08, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Uniden power max 5.8 it says E4 wont work any help
After a power outage I receive an E4 error on my Uniden PowerMax 5.8GHz base unit. Is this broke beyond repair? Or, is there some sort of reset to get the phone working again?
Jun 19, 2009 | Uniden Lands Phones
Uniden dxai 4288-2
most multi-phone systems require you to dock the phone in the main cradle to sync it up with the system. not sure if you tried this already but it's pretty simple to do. just insert handswt 1 into the main base (answering machine) then remove it and plug the second hand set into the main base. you also have to keep in mind thatr when you answer the cakk with say handset one the only way you can use the second handset is by transferring the call. if your phones handsets are equipt with a transfer button then that may the problem
May 13, 2008 | Uniden Cordless phone EXS9950
Uniden 5.8Ghz phone.
Jan 20, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
66 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
