Turn on problems - Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Check power supply then make sure that the main power cable is in plus the 4 pin and 24 pin are the main ones first then hard driver then cd or dvd rom cpu plug as well on board it says cpu fan try new power cord as well
Posted on May 03, 2014
Turn signals wont work but flasher an lights come on
If the hazard flasher is working but the turn signals aren't, the problem is most likely either fuse A11 or the #2 relay in the trunk fuse block. However, if these check out, the problem could be either the turn/hazard switch assembly or the turn flasher module.
If both the turn signals and hazard flasher are not working, the most likely problem is the turn/hazard switch assembly.
May 26, 2015 | 1994 Cadillac DeVille
Nokia 2700c-2 restart problem
I think you need a new battery charger
Mar 18, 2014 | Cell Phones
How to turn off theft the van cant start
cant turn off problem you can try another key.put key in the ignition turn on position for 3 seconds the security light should turn off.then turn off ignition switch wait 5 to 10 seconds try start vechicle if still fails to start.problem in the theft security system.dealership has to code scan problem could be in the ignition switch which is antenna ring.problem could be transponder key or problem could be in the immobilizer control module and ECM.
Feb 11, 2013 | 2000 Ford Windstar
Vw jetta 1995 2.0 having problems with the turn
TELL ME WHAT PROBLEM YOU HAVING.IF TURN SIGNAL LIGHTS DONT WORK YOU CHECK BULBS + SOCKETS AND THE FUSE.IF ALL OKAY PROBLEM IS IN FLASHER UNIT SWITCH OR LOOSE OPEN WIRE CONNECTION.IF EVERY THING CHECK OUT GOOD TURN SIGNAL SWITCH IS FAULTY.
May 26, 2010 | 1995 Volkswagen Jetta
The KE970 keeps turning off by itself, without warning
its a software problem other wise it is a problem of jack
Sep 09, 2009 | LG Shine KE970 Cellular Phone
My samsung keep turning off.
The turning off problem is just a symptom.
The turning off is the protection circuit shutting down the TV because a problem inside the tv is detected.
The TV must be tested to find the problem.
Apr 19, 2009 | Samsung HL-S5086W 50" HDTV
My monitor didn't display anything>.....
REMOVE ALL CONNECTORS AND ADDITIONAL CARDS.
EXCEPT POWER CONNECTION,
PLUG IN MONITOR TURN MACHINE ON.
DOE IT TURN ON IF NOT IT MAYBE A SWITCH PROBLEM.
IF TURNS ON THAN TURN MACHINE OFF AND PLUG IN ONE WIRE OR CONNECTION AT 1 TME AND TURN THE MACHINE ON, IF IT DOESNT TURN ON THAN YOU HAVE FOUND THE PROBLEM.
CANDYMANGANDY
Jan 27, 2009 | Biostar P4M890-M7 Motherboard
Starting problems
Clean & inspect battery connections & have battery load tested.
Dec 19, 2008 | 1996 Dodge Caravan
Does not turn on
I have got the exactly same problem as you have, i just pull the plag and wait couple of days.. then turn it on again. it just open like a normal.. but when you finished with tv and turn it off... it occure the same problem again.. think we need service.
Mar 28, 2007 | Sony Grand WEGA KF42WE610 42" Rear...
Computers & Internet Logo
David Payne
David Payne
