Question about Garmin zumo 550 GPS Receiver
Plugged into car mount, Zumo 550 switches to usb mass storage
When plugged into car mount or motorcycle mount, my garmin Zumo 550 switches to usb mass storage mode... How do I stop it from doing this?
Thanks!
Rob
marcelbakker
  • 174 Answers
SOURCE: Import *.gdb route file in Garmin Zumo 550
Import to pc or to garmin device? There is some info in the manual, however you will need an SD card to work with triplogs.
Posted on Jul 23, 2008
SOURCE: garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
Posted on Jul 13, 2009
mindreader
  • 578 Answers
SOURCE: how do i reset my garmin zumo 550
Press and hold Power and + at the same time.
Go to http://www.manualnguide.com/dl/4354/ for more information.
Posted on Nov 22, 2009
SOURCE: Garmin 550t. When i have my zumo on my motorcycle
Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
Posted on May 19, 2010
How to fit zumo 550 to honda goldwing 1800a6
What I did was got an aftermarket holder for the GPS and plugged it
into a cigarette lighter holder, commonly available at auto parts stores, that I wired to the battery .
Aug 03, 2014 | Garmin zumo 550 Motorcycle GPS Unit
How do I obtain more storage space on my Zumo 550
I don't believe that there is much else you can do but before i say that try using a 4GB sd card, think they can handle that. These units have a certain amount of memory reserved for system use and they will allow nothing else to use it. In the event that something does use it you get the "not enough memory to run program, Shutting down" error. Always fun
Jun 11, 2010 | Garmin zumo 550 GPS Receiver
GPS is not getting power on the motorcyclen mount.
If you're sure the power cord is getting power, then the mount has likely failed. Mine has failed 3 times. Replacing the mount will fix the problem as it did on mine. If the unit is less than 1 year from purchase, Garmin will warranty replace it for free. If not, it'll cost you about $85 plus shipping to put a new one on.
May 09, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Zumo Wull not charge form bike mount
Experience the same problem with my Zumo 550. Told by service advisor @ Radio World that this is a common problem. Unit needs to be charged on the DC charger occasionally. The motorcycle mount and car mounts, I was told, does not charge the battery on these units, but maintains a charged battery.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
My garmin zumo will not turn on.
Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
May 26, 2008 | Garmin zumo 550 GPS Receiver
No power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Dec 22, 2007 | Garmin zumo 550 GPS Receiver
Transfer Problems
I locked my garmin zumo 550 and forgot the passcode
Oct 11, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
129 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
