Question about Dell ST2210 21" Monitor
Fuzzy text connection is through a vga cable but getting fuzzy text,and software is incompatible with my tower
    Master:
  • Dell Master
  • 788 Answers
You need to test the DVI port and use the DVI-VGA adapter if your computer does not have a DVI port.
Posted on Mar 01, 2014
Dual Monitors - why does my second monitor have bad picture?
As long as something isnt broken, using the HDMI and the D-Sub should be fine. From your fuzzy pictures I suggest that you want to double-check your cables.
Have you tried to switch it? If you put the second monitor on the D-SUB and the picture is still faulty, its very likely the problem is your monitor.
Dec 29, 2011 | LG 22" FLATRON LCD Monitor
We were given a dell computer and that morning the people who gave it to us said it was working fine, they wiped it clean and we were goin to have to reinstall everything, but the monitor wont work plugged...
Does the light on the monitor show?
If not check poer cable - if so check the connection on the computer black cable with blue end.
Any beeping when the computer is turned on?
if so you may have a hardware malfunction with the tower.
Aug 29, 2011 | Dell Dimension 2400 PC Desktop
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
The power led is flashing and the monitor will not turn on
Hi
usually for these kind of issues., here are some common steps that helps at times.
1. Check the VGA Cable that connects the Monitor to the Tower (CPU).
2. Reseat the Cable once.
3. Remove the VGA Cable & turn on the Monitor Alone. See if you get any display saying "No Signal" or anything similar. If there is some display, then it means that the problem is with the Tower (CPU) & not with the monitor.
Hope this small sugession helps.
Cheers!!! Have a nice day!!!
Sep 14, 2010 | BenQ FP567s 15" LCD Monitor
No visual in my monitor
Hi
Sep 14, 2010 | Dell Dimension 8400 PC Desktop
How can i go dvi - hd to vga to my hp a1010n tower
DVI - VGA cable adapter. One side is DVI and the other is VGA. Connect VGA side to your pc's video output and then plug the DVI cable to the other
Nov 27, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
Vga lead will not fit tower
Try turning it around. If it still doesn't fit, you may need a DVI to VGA adapter.
Aug 05, 2009 | Xerox Computers & Internet
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Jul 19, 2009 | Dell UltraScan P1110 21" CRT Monitor
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Dell ST2210 21" Monitor Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
