Question about Alpine Ktp-445 Head Unit Amp Power 4ch Amplifier Ktp445
Alpine power pack
A whine comes out of the speakers when you power unit on...only when connected to the power pack. there is no difference in power between the power pack and the head unit. is the unit defective?
SOURCE: Alpine CVA-1004
lol i had the exact problem that you are having with my alpine. The solution is taking the blue cord that was inside the vehicle (forgot what cord it was) and actually connecting it with the other blue cord thats different makes the factory amp read the cd player and ta-da it works. crazy isn't it
Posted on Apr 04, 2007
SOURCE: alpine cda 9812 rb cd player
have u checked the fader
Posted on Mar 02, 2009
hack124x768
  • 33 Answers
SOURCE: connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Posted on Mar 28, 2009
  • 11 Answers
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
budice7h20
  • 93 Answers
SOURCE: I got the alpine cda 7892 head unit. I hooked it
Take it back.
Posted on Jun 27, 2009
I need help hooking up a rca converter box in a Lincoln town car carter with the alpine stereo system
Is the converter powered or passive? Each RCA (red or white) connection represents a + and - speaker wire for one speaker or channel. So assuming you already have the amplifier you'll cut the speaker wire coming from the head unit. From the head unit speaker wires will attach to the input or hi-level connection on the converter. The other half of the wiring goes to the speakers in the doors. Those will go to the amplifier which is or should be fed by the RCA's on the hi-level converter box.
Passive coverters don't require 12v power but active ones will need 12v input from a remote signal such as from ignition circuit or a power antenna to turn the unit off and on so your battery isn't drained with the car off.
Feb 28, 2017 | Alpine Car Audio & Video
I have a cda. 9887. It powers on but gets no sound from any of the speaker wires. What could be wrong. What can I try.
Most Alpine CDA units come with an option to turn on/off the internal amplifier in order to give you better sound when connecting an external amplifier. Try turning on IC
Aug 15, 2011 | Alpine CDA-9887 CD Player
Im adding a alpine cda9884 headset with a ktp-445 already installed on it into my 96 grand cherokee. I am. Going from the ktp445 straight to the speakers. My problem is i cant get anything at all out of...
how is the signal going from headunit to the power pack? Should have a harness from the power pack to the deck (h/u). then out to the factory harness in the jeep. remember there is an amp under rear seat so you need to bypass that to make everything work. yes the blue/white wire from deck to blue/white wire ath the power pack (amp) should be connected in order for the power pack to turn on.
Oct 20, 2010 | Alpine KTP-445 Car Amp
ALPINE TMX-R1000 ISSUES
You don't have S-Video coming out of it, although it looks like it. It's actually a bundled cable that carries power, video, audio, and control signal for an Alpine DVD player. It plugs into an interface box that has the actual power connections and inputs/output, and the control cable for an Alpine DVD player. I know this is an old post, but if you still have the unit and would like to sell it, or if you want to get the interface box, I can help you...
Apr 28, 2009 | Car Audio & Video
Removing alpine receive from dash
Unless you have the 'keys' that came with the unit, you'll need an Alpine dealer to a) get keys so you can remove yourself (wiring just un-plugs) or b) installer. CStereo mfgrs use different snap-lock mechanisms and sometime different keys for different models.
Apr 21, 2009 | Car Audio & Video
Alpine mrd m500 amp is not pushing my 12 in infinity sub
If you have a dual voice coil sub, make sure that you have the positive and negative terminals connected properly. If you have ONE of the coils wired backwards, it will cause the speaker to produce little or no sound.
Have you set the gains properly?
Are you sure the amplifier is receiving a strong signal from the head unit?
Have you tried it with a different speaker?
Jul 19, 2008 | Alpine MRD-M1000 Car Audio Amplifier
Alpine kca-420i when hooking up to alpine iva-d901 screen says no magazine and i pod doesn't power up
  1. Make sure your iPod has a fully charged battery before connecting it to the KCA-420i. When you connect it for the first first with low to no charge left, the receiver will not recognize it.
  2. Check all your AiNet cable connections. These connectors can be finnicky if they are not plugged in ALL the way and can come out when reinstalling the head unit
  3. Make sure your head unit is in Changer mode after verifying the above.
Jun 08, 2008 | Alpine Car Audio & Video
No sound from speakers after mra-f350 connected to alpine w205
Did you set the digital output to the on position on the bottom of the head unit?
You have to switch the head unit off then back on for it to recognize the position of the switch.
Oct 27, 2007 | Alpine MRA-F350 Car Audio Amplifier
Alpine CVA-1004
Sep 17, 2006 | Alpine CVA-1004 Car DVD Player
Alpine Ktp-445 Head Unit Amp Power 4ch Amplifier Ktp445 Logo
16 people viewed this question
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
