My Toshiba 32L1300U the sound rattles rattles or like static since the speaker on the bottom maybe it sets too close on the table it sets On Could it be the cord that stream or feed I am using a used cord
  • 7 Answers
When the cones are weak they let the coil on the bottom rub against the magnet. The only solution would be to replace the speakers.
The other possibility is the impedance is incorrect from the device you're feeding into it. In other words let's say you took wire from output that is supposed to go into the a speaker and plug it into the mic jack. This signal is already amplified and went sent through the amplifier in the PC it will be completely distorted.
There are ways to correct this but involves matching transformers. I'm sure you don't want to get into that.
Posted on Dec 25, 2013
    Top Expert:
  • Computers & ... Master
  • 22,127 Answers
You may need to reduce the bass as they are only designed for speech.
32L1300U
In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
Mar 26, 2014 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
Toshiba manual
where is channel set up???-english please
Dec 28, 2013 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
A205 speaker replacement
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft Static Free cloth, on the table you're working on. Helps prevent scratching the table, and laptop.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
You're going to remove the Top Cover. BEFORE this is removed you're going to need your ESD wrist str-ap on.
Electro Static Discharge
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components in a computer.
Wear an ESD wrist strap, have it's alligator clip attached to a good ground source; and your laptop is safe from Static.
Average cost is $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The Processor (CPU) is the MOST susceptible hardware component to Static Shock!
Don't wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; and you can use your laptop for an expensive doorstop, or conversation piece. (Oh that? Yeah, Static got it")
[Page1::Page2::Page3::Find another model; is on the Top and Bottom of all pages in White ]
Go to Step 1 and follow through to Step 17 on Page 3.
The Keyboard Bezel has to be removed,
Keyboard,
Display Assembly,
Top Cover. (Palm Rest Cover),
plus the other components to facilitate removal of the above.
In Step 17 you see the Speakers. They are a large unit that can only be accessed for removal, after removing the Top Cover.
Look for a part number on them. It is a Toshiba part number.
Put Toshiba + part number, in your browser search bar, and look for replacements. (No -> + )
http://www.discountedlaptopparts.com/toshiba-satellite-a205-left-and-right-speaker-set.html
Just for a point;
The above speakers look similar (To me), to the ones in the Irisvista link. (Pictorial disassembly guide)
Searching just now out of curiosity, I saw different styles shown, for the Satellite A205.
Point being I would want to see a PHOTO of what was being sold, to see if it is the right one. A lot of ads for Toshiba Satellite A205 speakers, didn't post a photo.
Could be different speaker examples for the different model numbers, of the model series.
(A205 is the Model Series. The number/letters after that designate the Model Number)
Seems that Toshiba STSA205 is the number, but you will know when you remove the speakers.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 12, 2013 | Toshiba Satellite A205-S5831 Notebook
Toshiba satellite CD door will not open
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
The sound is starting to break up on my samsung lcd tv which is less than 2 years old?? LA32B550K1F.
The TV speaker's have a sponge surround suspension. After a few years the sponge starts to powder and fall off.Then you start to hear a rattling sound at some frequencies. You can confirm this by keeping your ears near the bottom of the LCD panel ( near the table stand base ). If you go into the sound menu and reduce the Bass settings it will give you some relief. The only solution is replacing the speaker for which you need professional help.
Mar 09, 2011 | Samsung Televison & Video
My son installed speakers on my Toshiba laptop
Right click on on the speaker icon. Click on adjust audio properties. Under the volume tab, if the mute is selected, deselect it. click advanced under the speaker settings. Select laptop stereo speakers.Click OK. close all windows. Restart.
Jan 25, 2010 | Toshiba Satellite A135-S4527 Notebook
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
No sound from speakers and static from earphones
First, let's deal with the speaker problem. Download the latest device driver software for your notebook's built-in audio from csd.toshiba.com, install the software, and make sure the "mute" icon does not appear in place of the volume control.
As for the headphone issue, make sure your volume is set properly and the cord on the headphones is in good condition. Again, update your laptop's device driver software, and if that doesn't take care of the issue, call Toshiba and they can help you.
May 04, 2009 | Toshiba Satellite A215-S5822 Laptop
Realtek audio speakers crackling..
To fix this:
Go into realtek, go into every device and go to format, and select the lowest format (should be 16 bit) that should lower crackling SUBSTANTIALLY.
Then right click the speaker and click playback devices, now right click your speakers and click properties, then go into enhancements and click immediate mode and then click disable all enhancements. Works every time.
Jan 04, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
