Question about Frigidaire Dryers
Start drying cycle, hear gas ignite, then loses ingition while still spinning.smell of unburned gas briefly.
  • terkdad May 17, 2009
    I don't know yet, heading to garage to review and check suggestions. I will update with resolution(s), or lack thereof.
    Brigadier General:
  • 8,619 Answers
Hi!
You have to check the following things to resolve the issue your are facing with.
Door switch : If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse : On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring : Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Vent : Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element : Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork : Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat : Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 17, 2009
2001 ws6 6speed Trans am no start. Will crank over but will not fire. Can hear fuel pump turn on with key. Also smells like raw fuel. Fuel is new 91 octane.
Its flooded at this point. let it sit & plugs dry. Diagnose no spark problem, Don't keep turning it w/o spark. The oil is getting all the unburned fuel. Change that oil after u diagnose spark problem. could be coil, ignition relay, ect.
Feb 19, 2017 | Pontiac Cars & Trucks
Igniter keeps firing without being turned on.
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter.
Jan 31, 2011 | Thermador 37 in. SGSX365 Gas Cooktop
Once burner lights the "clicking" of the ignition
Jan 30, 2011 | Viking 37 in. VGSU161 Gas Cooktop
Gas ignighters continue to spark after gas is ignighted.
Jan 11, 2011 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Dryer spins but dosen't get hot
Since you indicated that it had an igniter I assume you have a natural gas or propane model. I had some trouble with a Hotpoint dryer and replaced the igniter. That didn't solve the problem. I then decided to just change the gas solenoid and the flame sensor at the same time and it worked fine again. I got them both cheap from Ebay from the same seller.
The flame sensor tells the machine if the ingiter was able to light the gas burner. If it doesn't sense the heat it will turn off the gas solenoid so your house doesn't fill with gas. The gas solenoid is an electrical valve that lets the gas flow into the burner. You should be able to hear the gas solenoid click when it opens and then your igniter will glow and start the flame. If it shuts itself off within a minute of that then I would suggest the flame sensor as a starting point. If it never clicks then I would start with the solenoid.
Good Luck and post back here if you solve it for the next person with your trouble.
-- Kevin
Sep 27, 2009 | Maytag Dryers
My 2005 sonata starts after trying several times. It just turns over like a car out of gas, then usually on the third time it will start.
Sounds like its either fuel or ignition. Have someone turn the car over while you sniff the exhaust.
If it smells of raw unburnt gas , fuel is not the issue , your problem is most likely ingition. Car might run rough at first when it does start , due to being slightly flooded.
If no gas smell probably a fuel problem. Possible low fuel pressure , or no fuel injection.
May 08, 2009 | 2005 Hyundai Sonata
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Gas dryer drum will not spin
the flint element might need to be replace...(pilot light) I had the same problem the dry had a burned smell...which meant that the element wasn't working properly and finally the drying wound't heat anymore
Jan 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Jan 16, 2007 | Maytag MDE2706 Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
