Question about Geovision Home Security
Gv750 can't find usb protection key for new version system
My 32GB USB Drive needs formatting but when I try it says that it is write protected. How do I remove the write protect?
Follow the steps to remove the write protection from the pen drive:
1. Open the Windows Registry Error by pressing a shortcut Windows-r
2. Type regedit into the form and press the return key on the keyboard.
3. Navigate to the following Registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
4.Double click the key Write Protect in the right pane and set the value to 0 In the Value Data Box. Press OK
5. Exit Registry
6. Restart your computer and re-connect your USB pen drive on your computer.
Mar 05, 2013 | Computers & Internet
Usb drive I/o Device Error
You have probably seen the following scenario in multiple thriller and spy movies; A spy connects an USB stick to a computer to copy data from the computer to the device. Movies do not necessarily reflect reality but there is some truth to this scenario after all. It is indeed possible to connect an USB device to a computer running Windows to copy data from that computer to the removable storage device.
It is sometimes in the best interest of companies, organizations and individuals to protect the data on their computer from being copied this way.
Microsoft has added options to the Windows operating system (more precisely to Windows XP and newer operating systems) to write protect all USB devices that are connected to it. This indicates that it may not always be possible to protect the computer this way, for instance if data needs to be written to USB devices regularly.
Write Protection adds another layer of defense to the computer. The system is not fool proof on its own, as it is still possible to copy data, for instance by uploading it to the Internet or a network connection.
Write Protecting USB Devices
You can enable or disable write protection of all USB devices that are connected to the Windows operating system. Both settings are configured in the Windows Registry. Here is how this is done.
Open the Windows Registry editor with the shortcut Windows-r, enter regedit into the form and press the return key on the keyboard.
Please note that you may need to create the key StorageDevicePolicies if it does not exist. Select the key afterwards and right-click into the right window. Select New > Dword (32-bit) Value from the context menu and name the entry WriteProtect.
Double-click the new entry afterwards and change the value from 0 to 1. A value of 1 disables writing to all connected USB devices. If you want to enable writing again you need to change the value of the key to 0.
Nov 03, 2012 | Kingston Dt101g2/8gbz Flash Memory
Write protected cannot format the usb.
try to remove partition on to disk management tools and make new partition then reformat the USB drive be careful not to delete the other drive.. or use a software that can manage drives like paragon or acronis partition manager .
Aug 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I JUST BROUGHT A NEW PEN DRIVE. FIRST TIME USING IT, AND THE PROBLEM ALREADY HAPPEN. IT IS WRITE PROTECTED. I ALREADY DONE EVERY POSSIBLE WAY TO GET RID THAT WRITE PROTECTED., BUT IT DIDN'T SUCCESS.. I...
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 11, 2011 | Kingston Combo 4GB DTI USB and 4GB...
Symantec anti virus auto protection disabled why
Most likely you have a Microsoft virus. One of the first actions of a virus is to disable any anti-virus software it finds. Remember which comes first the virus or the ant-virus? With 70% increase year on year of M$ malware it is extremely difficult to deal with.
The best solution is to simply move over to Linux and to dump M$.
Firstly all the software including operating system is free. Secondly Unix and Linux are secure by design and cannot have viruses.
And then one should remember that computers have been going a very long time. Unix last year celebrated 40 years (1969). And of course, there has never been a virus on a Unix or Linux system ever.
Windows in contrast is insecure by design and di not come out until 1992, so it is very new and very bad system.
But, to answer your problem what I usually do in such situation is to download using another machine the full version of AVG free from: http://www.filehippo.com/download_avg_antivirus and also download the updates from:- http://free.avg.com/gb-en/download-update
Now, put these files on a USB key and then plug it into the infected machine. Install the AVG free from the USB key. Do the updates from the USB key. Do a full system scan
And do this work with the infected machine prpoerly disconnected from the internet.
Only after you have done all this should you reconnect to the internet.
Good Luck! - I am so GLAD I do not use M$ and I have been using computers pretty aggresively ever since 1971.
Sep 13, 2010 | Symantec Computers & Internet
I installed a copied version of Flexi Sign pro 7.5 and it tells me that I need na hardware key installed
I installed the flexisign7.5 on windows 7 but there appear a error massage that HARDWARE KEY NOT FOUND
Aug 25, 2009 | Computers & Internet
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Home Security Logo
121 people viewed this question
Top Geovision Home Security Experts
Lawrence Oravetz
Are you a Geovision Home Security Expert? Answer questions, earn points and help others
