Question about Genius GX Gaming SW-G2.1 1250 - 38W 2.1 Channel Gaming Speaker System, Wooden Cabinet Subwoofer with Rich and Deep Bass
Only get sound from one speaker (GX gaming) but when i switch the cords i can see both work but sound only comes from 1 of them
Genius gx gaming speaker 3000 problem.... My speakers where working fine, but now I have no sound and the blue like flashes every 5 secs.
If your speakers have a separate power supply, the flashing blue light suggests there has been a power supply failure
Apr 11, 2013 | Audio Players & Recorders
My ihome won't work. The ipod is playing, but there is no sound coming out of the ihome nor is the radio working.
Make sure you have power to the unit. Do you see indicator lights that show the unit is working. Speaker switch on?
Aug 31, 2010 | Audio Players & Recorders
I have a Technics Stereo Receiver SA-GX 500. There is very little sound coming out of all the speakers (A and B) as well as the headphone jack. I have made sure that the speaker button is depressed (A, B...
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Aug 08, 2010 | Technics SUV500 2-Channel Amplifier
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
If a sound card is listed, you have one installed.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
Cant get speakers to work
if it is a hardware problem
check to see there is no red X through the speaker this means it Muted if so double click the red X and you will be turning them back on
turn off your computer
1. plug them in most pc's its the green female is the speaker out.
2. do you have power attached to the speakers if you got a power supply or power cord plug, make sure that it is pluged in.
3.turn on your computer.
when you see your desktop see if a speaker is present on the right hand
side of the task bar your in luck
If it is a Software proublem
1.right click on my computer and click on properties.
then click on hardware, then device manager
2.expand sound, video and game controllers the + sign next to the speaker
4. if you notice a yellow exclamation point on sound, video and game
controllers that usually means it's a driver or software
you might need to reinstall the sound cards driver
Mar 15, 2010 | Audio Players & Recorders
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
Sound not working
i guess u need a new internal speaker to prove that try use the phones
Aug 25, 2008 | Sony PlayStation Portable (PSP) Console
Onkyo SC 570 stereo speaker has hissing sound
if you already switch the speakers to make sure that is NOT the receiver , then theres two things , check the TWEETER or check the capacitor or Crossover inside the speaker box , you gonna need a multimeter for this task . hope it helps
Apr 19, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Genius GX Gaming SW-G2.1 1250 - 38W 2.1 Channel Gaming Speaker System, Wooden Cabinet Subwoofer with Rich and Deep Bass Logo
52 people viewed this question
Top Genius Audio Players & Recorders Experts
ptpumpman
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Genius Audio Player and Recorder Expert? Answer questions, earn points and help others
