Question about E-Machines etower 466id PC Desktop
The Monitor Will Not stop saying emachine
I have everything pluged in but it wont leve that screen
  • 2 more comments
  • Art Ellison
    Art Ellison May 11, 2010
    I agree--your computer is not starting up. You'll need to do some further troubleshooting.
    How good are you at taking the computer apart so we can solve it?
  • Onyebuchim Obike
    Onyebuchim Obike May 11, 2010
    could you please clarify the issue.
    When you start up the PC is the EMachine is always displayed and seems to not go out?.......
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    is this an emachines computer and, emachine monitor?
  • Dick
    Dick May 11, 2010
    Your computer is not booting. Has it ever worked? What has changed since the last time it worked?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
You may have a failed motherboard or a failing/failed power supply unit (PSU) then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting anything after the "splash" screen. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components (bigger video cards, more drives, etc) without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights or move past the e-machines display) then you probably have motherboard issues. If you have another PSU that has the same or greater output watts you can try replacing that first. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not mean no power, just not enough to run the computer. Let us know.
Posted on May 20, 2009
HI MY NAME IS JANIE, AND I HAVE AN ISSUE WITH MY PS,, MY MONITOR SHOES AN "INPUT NOT SUPPORTED" MESSAGE AND I TRIED UNPLUGING EVERYTHING AND PLUGING IT BACT IN ORDER, BUT NOTHING WORKED SO FAR.
Your video card in your computer is better than your monitor. That is good though as we can just set the video resolution lower to accommodate your poorer monitor. Do you need help doing that? If so please supply Operating system type, such as Win XP Pro, Win 7 Pro....
You can email me if you like:
terracwc@excite.com
Dec 01, 2010 | eMachines Computers & Internet
When I press the button, monitor will not go on.
check if its pluged to the power. and if it is, check if the switch board is working correctly by pluging in another device.move the wires around a little bit, and if still it dosn,t work then your monitor is broken.. get it checked by a technician.
Sep 28, 2010 | E-Machines eMachines Monitor E15T4
Screen on my desk top monitor says its going into sleep mode cannot access safe mode monitor screen wont stay on long enough to do or see if anything works....,,, my pc is an hp a6500f , i replaced the...
Try using a different monitor or use that monitor on a different computer to see if the monitor is bad. It shouldn't have anything to do with your CMOS battery. I'd check to make sure the monitor itself is good before I go tearing my computer apart. Let me know how it goes and maybe we can get it figured out.
Aug 03, 2010 | E-Machines eMachines Desktop PC
Contrast/menu/screen resolution box wont stop flashing on screen.
try to clean around it's exit button sounds stuck
or unplug monitor for about 20 minutes
if the problem persists i would reinstall driver
Jan 09, 2009 | E-Machines eMachines Desktop PC
NEW LG monitor to work on emachines PC with adaptor
First of all, most monitors now a days are plug and play. Make sure the monitor is secure on both sides. There is also another connecter like the one attached to the CPU on the monitor, so make sure they're both securly attached. Also make sure you have the connector plugged in the correct monitor port. some computers have 2.
Jul 18, 2008 | E-Machines eMachines Desktop PC
No picture
have you tried clening out the conetor end or unpluging it the pluging it back in
Jun 09, 2008 | E-Machines eMachines Monitor E15T4
Flashing osd
It would help to know what the OSD says; is it a message from the monitor or from the main system?
Apr 28, 2008 | E-Machines eMachines Desktop PC
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
Emachines t2865
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Feb 17, 2008 | E-Machines eMachines Desktop PC
E-Machines etower 466id PC Desktop Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
