Question about Craftsman 25cc Gas Line Trimmer
Not getting gas and the primer bulb wont pump
    Problem Solver:
  • 8 Answers
Sounds like the hoses need to be replaced, open the tank, (make sure its empty) ull see some hoses, look and see if they are cracked
Posted on May 21, 2009
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
I cant get it to start. The primer bulb wont refill with gas
The bulb pulls fuel from the carb into the bulb and back to the tank, if the bulb does not fill it is because there is a fuel blockage, either in the fuel filter in the tank, or the screen in the carb itself.
Jun 03, 2012 | Echo 135 mph 390 CFM Gas Blower PB-250C
I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Jun 17, 2011 | Homelite Garden
Model 2175 poulan - pump up primer bulb and it colapses. When i put fuel in head it runs till gone..
Change out the primer bulb and the small gas lines going to carb and primer. One of these has a small crack to let air get by and this is how you get a flat primer bulb. Pick the kit up at lowes for $6-8.
Feb 03, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My home lite blower wont start not getting fuel how does the primer bulb work
Primer bulb pumps fuel from gas tank to carb. Once started gravity takes over.
Oct 09, 2009 | Homelite Garden
Primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman 25cc Gas Line Trimmer Logo
487 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
