Question about Toshiba 42HM66 42" Projection HDTV
When trying to start tv green & yellow light flash and then after a few seconds it goes off
cammykins
  • 149 Answers
SOURCE: Toshiba 62HM14
Here is some useful information off of the manufacturer's product information PDF regarding the lamp problems/issues: LED indications: The green and red LED lights on the TV control touchpad (on the lower right corner of the TV screen)indicate the TV?s current status, as follows: ? Green ON = Control touchpad being pressed. ? Red ON = Power ON. ? Green and/or Red blinking 35) Special care for D LPTM (digital light processing) units: ? Lamp?The lamp in this product has a limited service life. The length of service life varies depending on product use or user settings. If you use the lamp beyond its service life: - you may notice a reduction in the colors and/or brightness of the picture, at which time you should replace the lamp unit; and - the strength of the quar tz glass in the lamp will be reduced and the lamp may rupture. If the lamp ruptures, the TV will not operate until the lamp unit is replaced. Here is more info: LED Indication Condition Solution: 1) Green lights solid; Red blinks at 0.5-second intervals. 2) Green blinks at 0.3-second intervals; Red lights solid. 3) Green and Red blink at 1-second intervals. 4) Green is off; Red blinks. 5) Green and Red blink three times. The lamp unit door is not seated properly.The lamp is not working properly. The lamp is not working properly after the eighth automatic restart (see item#2). For service personnel only. An abnormal temperature increase has occurred. Turn the POWER OFF and unplug the power cord. Review ?How to replace the lamp unit? on pages 57?59 to ensure that the lamp unit door is installed securely. If the problem persists, contact a Toshiba Authorized Service Center. The TV automatically will try to restart itself eight times.Turn the POWER OFF and then ON again. If the problem persists, replace the lamp unit (see pages 57?59). If the problem still persists, contact a Toshiba Authorized Service Center. Turn the POWER OFF: and unplug the power cord. If the problem persists, contact a Toshiba Authorized Service Center. Do not block or cover the slots or openings in the TV cabinet. If the problem persists, contact a Toshiba Authorized Service Center. _______________________________________________ Good luck! I hope this helps you out!
Posted on Sep 07, 2007
SOURCE: won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Posted on Dec 09, 2008
  • 126 Answers
SOURCE: Without any warning my tv started turning itself
That is usually a sign that the bulb needs to be replaced this only occurs on projection TV's you might look into a new TV because the prices are better and so is the picture and a new bulb is going to run you a few hundred dollars plus labor. I had this happen a couple years ago with a mitsubishi i owned the bulb was $300 and the labor 75 for a couple hundred more i got a new one instead but mine was a 42"
Posted on Dec 03, 2010
SOURCE: I have a Toshiba 56HM66 DLP projection tv. The
My tv has the same exact problem have you figured out what it is ??
Posted on Jan 05, 2011
eagle338
  • 4889 Answers
SOURCE: The screen went blank and green light started
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Posted on Feb 25, 2011
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Try to turn on ps3 green light comes on for a second then yellow ligt starts flashing then goes to a flashing red light?
they yellow light means a system fail. i found a website that will fix it and in a short amount of time and save your data. www.videogame911.com
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Goes off suddenly then restarts a few seconds later
You need to replace your main board.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 11, 2008 | Vizio L32 32 in. LCD HDTV
Won't come on
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 42HM66 42" Projection HDTV Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
