Question about LG KF600 3MP InteractPad Triband Phone Silver w/1GB
Switches off when charging or plugged into usb port
Kf600 mobile always switches off either when charging in mains or in usb port on computer
    Problem Solver:
  • 11 Answers
My phone does this too. i dont have the same one but when charging just try to hold the power button down
Posted on May 17, 2009
My Samsung Galaxy SII's battery icon is flashing
it maybe the problem with the port, goto mobile repairing shops and change the port with new one , it doesnt cost much..
Oct 02, 2012 | Cell Phones
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.
OR
Purchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
Aug 13, 2012 | Toymax Audio Players & Recorders
Nano
Connect the supplied USB cable to the Nano and then plug it into the USB port on your computer. The computer's USB port will charge the battery as well as downloading music files to the Nano.
You can also use a mains powered USB adapter to charge USB devices like your Nano.
Dec 19, 2011 | Audio Players & Recorders
Charging Light is on when battery in , and charger plugged in , no reaction when power switch is pressed , fan not spinning ,no power light ,nothing . When battery take out , no charging light when charger...
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Apr 05, 2011 | Compaq Computers & Internet
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
Do you leave camera on as it is charging through computer for the Kodak Easyshare M753 Camera?
Hi it dont need to be on whilst charging, some cameras will switch themselves on when you plug them into the computer, but you can still turn it off, now you need to bare in mind that unless you are using a powered usb port is one that plugs into the mains then into your computer you may have problems charging the camera enough through the computers own usb port, it may still charge so you will have to try some cameras will just power up enough to enable you to transfer pictures onto your computer.
give it a try and see how you get on, it wont matter if the camera is on or off whilst plugged into computer how ever it will charge quicker with the camera off if it will even charge at all
Jul 17, 2010 | Kodak Easyshare M753 Digital Camera
I have a 30g Zune which has not been holding a charge for a couple of weeks. This morning the Zune powers up and then shuts off (even while plugged in). I tried the 'hold down the back button and up at the...
I am not sure if this is gonna work but, since you've tried all other steps why dont we give this a try too...LOL :-)
To troubleshoot this issue, try one or more of the following methods in the order in which they are listed:
  1. Let your Zune device charge for 30 minutes, then disconnect and reconnect the cable to turn on the player. It can take up to 3 hours to fully charge.
  2. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
  3. Use another supported high power source, such as an Xbox 360 console, a Zune AC Adapter, a Zune Car Charger, or a Zune FM Transmitter/Charger.
    Note These devices are sold separately.
  4. If you are connecting your Zune device to a mobile computer, make sure that the mobile computer is plugged in and is not running on battery power. Many mobile computers are configured to conserve power when they are running on battery power to extend battery life. This behavior may affect Zune device charging.
  5. If the Zune device is charging slowly, be aware that, for optimal charging, the Zune device requires at least 500 milliamps (mA) of power. Frequently, USB ports that are located on the front of a computer and on some USB hubs are low-power, 100-mA ports. Typically, the high-power, 500-mA USB ports are on the back of the computer. Additionally, when you suspend the computer or put the computer to sleep, high-power USB ports may be switched to low-power, 100 mA mode.
  6. If the device boots to the home screen but is still not charging correctly, continue with the "Home screen is displayed" steps in the following section.
    If the device continues to display the full-screen charging icon, continue with "Full-screen charging icon is displayed."
  7. If the battery in the device still does not charge correctly, visit the following Web site to sign in and register your device: http://service.zune.net (http://service.zune.net)
    At this Web site, you can submit a request for service if your device qualifies for service.
Dec 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have a Dell Latitude D600 laptop whose USB port is being used to charge the battery in an iPod Shuffle music player. The laptop shuts down after about thirty minutes of inactivity, preventing the iPod...
You can use a powered USB hub to charge your iPod, MP3 player etc. without connecting to a laptop's computer USB port.
Just connect the mains adapter to the USB hub and then plug your iPod into the hub for as long as you need.
You can also use this hub for your computer/laptop when you need extra USB ports..
Jan 10, 2009 | Dell Latitude D600 Notebook
LG kf600 software on the pc doesn't see the connection with the phone, but the pc does
hi,
I have successfully install some applications on LG KF600.
0. Install application - LG Mobile Sync (to verify the driver in Control panel- system- Hardwave Device- Modem- LGXXX). If it did not show up, well it is normal. You may need to restart PC after installaion.
1. Select the USB conection (for LG KF600) from the connectivity option
2. Connect USB cable (connect to PC first) from PC to USB port of LG KF600.
NOte : your will see "portable disk" on your phone.
If you did not see it. Please stop.
3.Check My computer (from PC). Is there any NEW Removeable device appear ? Unplug and plug again from the phone and you will see it.
4. In your Removealbe device (phone), you will see 5 folder (actualy from Phone -My Stuff )
5.Copy files from PC to desired folder (phone).
Does anyone know where to get the english dictionary for LG KF600 ?
Sincerely.
Apr 06, 2008 | LG KF600 3MP InteractPad Triband Phone...
Can we make new charge for SAMSUNG K3?
You can easily get usb powerplugs for a few pounds from high street electrical shops or online retailers. It costs a few pounds. Why I even buy really cheap mp3 players on ebay for about £14 and they come with the usb power plug. The powerplugs are more useful than the players :)
Oct 26, 2007 | Samsung YP-K3 MP3 Player
LG KF600 3MP InteractPad Triband Phone Silver w/1GB Logo
93 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
