Question about SunFire V480 UltraSPARC III (A37WBPF408GRB) Server
Connect to v480 serial port - SunFire V480 UltraSPARC III (A37WBPF408GRB) Server
Connection of a subwoofer to yamaha rx v480 receiver
Get an output from the receiver pass it through a crossover and you will get a low frequency signal , plug in into the sub..there you go.
Feb 09, 2014 | Yamaha Audio Players & Recorders
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
Which port should I use for my printer: com 4 serial port com 6 serial port com 8 serial port usb virtual printer port
depends how your printer connect
if you realy are connecting an old serial printer com1 or com2 should be fine as long as you do not have a mouse or a modem on them ...
if USB any port is fine
if parralel printer you are only likely to have one...
Mar 18, 2011 | Computers & Internet
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
Ccr1cd keeps turning off my yamaha receiver rx-v480 keeps turning off when i turn it on
check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
Dec 24, 2008 | Yamaha RX-V463 Receiver
Hp pavilion a1547c motherboard,is there a serial port connection?
There is no serial port (or parallel port either) on this board. Here is a link to HP's site for all the information:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00683208&lc=en&dlc=en&cc=us&product=3203118&lang=en
Nov 22, 2008 | Computers & Internet
Cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Nov 15, 2008 | Cisco 2610XM Router
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Computers & Internet Logo
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
