Jukebox problems How do you put in your 45's in a seeburg m100c jukebox, 1952
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
No idea on this one but you could try asking here: http://www.pinballrebel.com/archive/seeburg/s100w/s100w.htm
Good luck with it.
Posted on Dec 27, 2013
3 Suggested Answers
  • 195 Answers
SOURCE: seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
Posted on Nov 03, 2009
  • 567 Answers
SOURCE: my seeburg disc jukebox skips a lot
try going into service mode to find the problem could be different things also you could try cleaning the laser this is one of the easy options
Posted on May 08, 2010
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
I have a Seeburg Select-O-Matic jukebox, model M1000, doesnt scan or move only spins, what could be the problem?It doesn't pick up the record or move at all, just spins.
I think you mean a Seeburg M100C
This is known as the "sit and spin" The main clutch is not shifting properly. This is a lubrication issue. the old grease has become glue like and is gumming everything up. The main clutch is located between the record rack and the record mechanism. Spray the s**t out of it with WD40 you may have to let it soak over night or take the record rack off. Don't remove it unless you have to. make sure that you blast that clutch (see pi of clutch) The thing at the thumb needs to move up and down freely. it work on gravity!!!
DO NOT REMOVE THE CLUTCH AS PICTURED
Remember you will need to spray through the record rack to get at it, so you will need a good flashlight to see it.
Make sure that the trip lever is not sticking. the can be gotten to easily. 24614542-gg2ae1cwkykr1dpptmtggk30-2-2.jpg
These pic may look slightly different from your C but the mech is basically the same. The trip lever in the pic is at rest. yours is likely up at an angle. Try raising it up or down after spraying.\
Once you get it moving again make sure you oil the piont with liquid bearings or other quality oil. Because WD40 will not keep it going it will gum up again if you don't oil. Do not over oil. it has a way of getting between contact that it's not supposed to. AND keep using it every day for a while.
Seeburg M100C
m100c-02.jpg m100c.jpg Ed.
Jun 11, 2014 | Wurlitzer Jukebox 1015 One More Time...
Jukebox problems
If you can't find a scan button to move the carriage then select a number at the other end of the rack so you can fill it
Dec 25, 2013 | Audio Players & Recorders
Jukebox seeburg scd-1a>1. turn on 2. select CD song 3. sound blares (50db) HIGH
hi I can put files of seeburg on a disc which includes amps,selectors,wall boxes,recivers,auto speed units
email me
Dec 15, 2013 | Computers & Internet
Seeburg jukebox sx 100 scans twice and returns
Regards
Alan Hood
ami-man
UK
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
I have a 1971 seeburg firestar jukebox - the zero (0) does not seem to work when you punch in the 3 numbers for the selection - so none of my selections that have zero in it do not play - also I do not...
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Mar 07, 2009 | Audio Players & Recorders
176 people viewed this question
 Grubhead
Grubhead
