Question about Cycling
Rear wheel huffy bicycle white disc that connects to the spokes is out of line. Need to re-attatch it.
  • Hank Bruce May 11, 2010
    Is the disc plastic between the spokes and the gear?
  • Michial Gueffroy May 11, 2010
    Are you talking about a plastic disk that protects your spokes on the back wheel ?
    Sniper:
  • 58 Answers
If you are talking about the plastic disk that attaches to your spokes, this is one of those parts that looks nice on the bike, but is not 100% necessary for safe operation of the bike. This disk is used to protect the chain from falling in-between the spokes and the gears.
If you need to reattach this, this should snap into the spokes without issue. If the clips that hold it are broken (as they often become) you can either learn to live with it, or take it to a bike shop to get the gear cassette removed and the part replaced. This is one of those cases where the tool you will need is more expensive than the part you will be replacing, so in my humble opinion, it is not worth the expense.
Hope this helps!
Posted on May 20, 2009
What is the o d on rear hub
Need better wording/explanation of the question - why do you need the info? The hub is merely the center part of the wheel - to which the spokes are attached, as well as the cog(s) that drive the bike from the chain. The outside diameter of the hub is not very important.
Feb 07, 2016 | Huffy 26 in. Cranbrook Cruiser Bike
Replace the spokes on my huffy 18 speed 27 inch bicycle
building and truing wheels is a specialized skill that takes a lot of practice. Most manufacturers use robots to build the wheels to save on labor costs. To have a human build a wheel can cost more than $50 per wheel for the labor. Spokes retail for about $1-$2 a piece and include a brass nipple. Spokes also come in different gauges. Most bike shops that sell spokes usually only carry a few sizes in stainless steel.
If you are only replacing one or two spokes you can take the broken spoke to a bike shop and they can measure it and hopefully have the right size in stock to sell you a replacement. Use the right size spoke wrench for your spokes to unscrew the nipple from the broken spoke, you will then be able to remove (spokes can be very flexible and will bend a lot to get them out of the hub). Observe the adjacent spokes and the lacing pattern to re-install the spoke in the hub and thread it into the new nipple that came with the replacement spoke. Put the wheel back in the frame and use the brake pads as a reference guide to tighten and true the adjacent spoke nipples until the wheel no longer rubs on the brake pads and you are satisfied.
My personal opinion is that on a Huffy, it is faster, cheaper and easier to buy a replacement wheel from your local bike shop for $35-$45. The spokes, rims and hubs used on Huffy's are of very low quality (most don't even use stainless steel spokes) and a new replacement wheel from your local bike shop (LBS) will be ten times better than trying to fix the old original equipment, IMHO.
Nov 18, 2015 | Huffy Cycling
How do you replace the spokes on the rear wheel of a huffy 18 speed bicycle
you will need several specialized bike tools that will make this cost prohibitive for the DIYer unless you plan on doing more wheels. Most local bike shops can sell you a replacement wheel for between $35 and $50 and remove and reinstall the freewheel, rimstrip, tire and tube and reinflate it for about $8-10. Also the quality of this replacement wheel will be a much higher than the original Huffy wheel.
If you still want to do it yourself, you will need a freewheel removal tool for your specific brand of freewheel or cassette (there are about a dozen different types of tools out there, so make sure you get the right one). You will need a spoke wrench of the right size for the spoke nipples you are using, there are three common sizes and a couple more odd size ones out there. You are looking at about $20-$30 for those tools. You should use a truing stand to true the wheel after the spokes are replaced ($150-$400) but you can "get by" with using the brakes in your bike as a reference. Spokes will run you $1-$2 each. If you don't have a special metric spoke ruler ($10-$15), most LBS's will measure them for free (all bike parts are measured in metric). The details of lacing a wheel and getting the tension right is beyond the scope of this short answer and I recommend that you either try to find a book on the art of wheel building at your local library or buy one off of Amazon ($25-$45), there are several good ones out there and video tutorials also. If you plan on doing more than one wheel then I highly recommend it and take the time to learn the art, there are few of us left out there that can actually build a wheel these days.
Rear wheel wobbely
Not enough info here. Is it the rim or the hub that is wobbly? If the rim is out of true (and not actually bent) the spokes can be tightened to bring it back into true. If the hub is loose then the bearings need to be adjusted. Either adjustment can be done by your local bike shop for $10-20. A broken spoke can also make the wheel go out of true, this will cost a little more to fix.
Sep 09, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
The back tire rubs against the frame only when I pedal. The tire wobbles a little bit while coasting, but appears to pull over to the frame while pedaling. Huffy Stonemountain 2 - 18 speed bicycle.
Either the wheel is mounted wrong, moving at the axle or the wheel is not straight true and strong (spoke tension issues). Look at it. Try to wiggle the wheel with your hand.
Use search engines for "how to" questions.
Jul 14, 2011 | Huffy Men Mountain Bike (26")
I bought a Huffy sea star 20 inch bicycle last year, the rear wheel keeps puncturing the inner tube, a spoke has come loose and the wheel wobbles. can't find a replacement wheel. Help!!!!!
Don't replace the wheel, get it fixed. The spoke can be tightened and the rim tensioned and trued. The rim strip probably needs to be looked at for exposing the spoke ends to the tube.
Mar 27, 2011 | Huffy Cycling
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
Cycling Logo
286 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
