Hotpoint wd420 clunking noises
Hi I have a Hotpoint wd420 washer dryer. The machine seems to wash ok (although sometimes there are bits of powder on clothes at 40 degree wash), but when the machine stops it will make clunking noises for up to about 20 minutes, and in that time you cannot open the door. Sometimes when it clunks, the door light will go off briefly and if you catch it right you may be able to open the door then.
Any ideas as to what the problem could be?
  • tony950 May 17, 2009
    it can be for any amount of laundry, small or large! finishes the program ok, its then that the clunking starts. i havent got a clue but could it be a door sensor of some sort?
  • 42 Answers
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
Posted on May 17, 2009
  • Yetimagic May 19, 2009
    Right, unscrew the lid of it , screws at the back (two usually then the lid slides forward to you, you may have to shock it a little, then lifts off, get your ear to it , run the cycle and then when it starts its thing find out where its coming from, it may be something really obvious and easy to fix, please dont get your hair tangled in it, dont get a shock through your ear either, go for it , what have you to lose? the Yeti
Check the bolts on top of the concrete block at top of machine haven't worked loose. Mine had machine worked ok but sounded really bad on spin cycle. Hope this helps
Posted on Jun 20, 2009
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Leaks from front left corner but only on certain washes and only a small amount
hello have you checked the door seal they tend to get holes in them. or the plastic powder dispenser check the hoses hope it helps
regards
shaun
Mar 06, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Sometimes when using the tumble dryer of my Hotpoint WD420 I get a puddle of water on the floor. Doesn't happen with every use. Do you know what the problem might be?
I suspect your dryer vent is blocked or partially clogged.. Also if your washer is not opperating properly putting wet close in the dryer could also cause this.....hope this helps!
Feb 19, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing comes out smelling horrible! Any ideas?
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
Please rate my solution.
Thanks.
May 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
