Question about GE XL1800 1100 Watts Microwave Oven
Need a replacement for the plastic grill of the GEXL1800 microwave
Need the replacement part for the plastic grill that cracked
  • GE Master
  • 9,047 Answers
You can find helpful exploded view diagrams and order parts by entering your part number or the full model number from the tag on the oven here.
Posted on Dec 28, 2013
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave Model JVM1540
If you mean the control panel, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you mean the door, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Feb 16, 2009
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
How to remove Panasonic microwave trim kit from around microwave built in oven?
You will see two indentations on the left and right plastic pillars that join the top and bottom plastic grilles together. Insert a flat head screwdriver into these slots and gently prise the pillar away.
Both pillars simply slot into place and can be pulled off and pushed back on when you have replaced the microwave.
Once the two pillars are out, you will see the four retaining screws that will allow you to take off the top and bottom heat grilles. Job Done. Hope this helps
Mar 31, 2011 | Panasonic Microwave Ovens
Hi My panasonic microwave nnv672s Inverter has stopped working. It powers on and goes for about 15 secs then stops. when in grill mode it is fine though. what should I do
I had the similar problem with my 667. My model had on the right hand wall a plastic plate covering the microwave emitter, secured by one screw. It is made of plastic so care is needed to remove it. I tried cleaning its surface with a number of methods, but the only one that worked was to take sharp knife edge to the surface ie. literally scrap the baked on material. Care in replacing this plastic shield is advised since it can crack if bent too much.
At first, there was no change in the prior symptoms and it even stopped working altogether. Since the "1" button gets used the most, I tried other numbered buttons and now it seems to be working correctly.
Hope this helps solve your problem.
Sep 22, 2010 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Front Plastic door is cracked and needs replacement.
Do not use a microwave with a cracked door as it could be emitting dangerous microwaves.
Sadly the cost of replacing the door would be more that the cost of a new microwave. Look for a good sale and treat yourself.
Jun 11, 2009 | Microwave Ovens
Ge spacemaker microwave jvm1630bkc
it is just behind the front top grill on the right. The plastic grill that goes accross the entire top of the front of the unit. Then behind it on the right is a small power board that has the ceramic fuse on it.
remove 2 srews from top of microwave that hold the top of this plastic grill in place.
Then slide the grill to the left or right (I don't remember which way). Now the grill will come out.
The fuse is usually the secondary issue. Most often, it is the cavity TCO that goes out. This is the thermo-coupler that breaks the main power circuit if the inside of the mocrowave gets over 100 degrees C. requires taking the unit down and taking the cover off.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
