Question about Vtech Lands Phones
Dect6.0cordless how do i remove 21 missed calls
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Enter the model of your VTech DECT 6.0 phone into the box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Posted on Dec 25, 2013
How do i delete missed calls from handset?
click on mute/Delete then
MUTE/DELETE During a call, press to mute the microphone (page 21). While reviewing the caller ID history, the directory or the redial memory, press to delete an individual entry
Mar 13, 2015 | Vtech DECT 6.0 Digital Cordless Phone
Get voice mail off phone and get phone callin
there is a simple code to turn voice-mail on or off at the phone eg
optus the code for the on off & the tutorial is 321 and for Telstra
TO TURN ON: **21*101*10# then press call/send
TO TURN OFF: ##21**10# then press call/send
now missed call service that's another question but I'd turn that off as well if it was me if you are not available let it ring out is my ethos
Voice mail & missed call service can both be turned off by the telco without any input from the user if that is what you want
Jan 12, 2015 | Vtech Lands Phones
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
How to remove call divert in the nokia 5130c
Check this by the way,
Menu > Tools > Settings > Phone > Call divert > Voice calls > If not answered > Activate > To voice mailbox.
or try
A few useful codes :
Call Divert (all call types)
All
Set: **21*destination#[SEND]
Cancel: ##21#[SEND]
Query: *#21#[SEND]
No Answer
Delay nn seconds: max is generally 30 seconds
Set: **61*destination*nn#[SEND]
Cancel: ##61#[SEND]
Query: *#61#[SEND]
Unreachable
Set: **62*destination#[SEND]
Cancel: #62#[SEND]
Query: *#62#[SEND]
Busy
Set: **67*destination#[SEND]
Cancel: ##67#[SEND]
Query: *#67#[SEND]
Cancel All
##002#[SEND]
Divert Voice Calls
All
Set: **21*destination*11#[SEND]
Cancel: ##21*11#[SEND]
Query: *#21*11#[SEND]
No Answer
Set: **61*destination*11*nn#[SEND]
Cancel: ##61*11#[SEND]
Query: *#61*11#[SEND]
Unreachable
Set: **62*destination*11#[SEND]
Cancel: ##62*11#[SEND]
Query: *#62*11#[SEND]
Busy
Set: **67*destination*11#[SEND]
Cancel: ##67*11#[SEND]
Query: *#67*11#[SEND]
Divert Data Calls
All
Set: **21*destination*25#[SEND]
Cancel: ##21*25 [SEND]
Query: *#21*25#[SEND]
No Answer
Set: **61*destination*25*nn#[SEND]
Cancel: ##61*25#[SEND]
Query: *#61*25#[SEND]
Unreachable
Set: **62*destination*25#[SEND]
Cancel: ##62*25#[SEND]
Query: *#62*25#[SEND]
Busy
Set: **67*destination*25#[SEND]
Cancel: ##67*25#[SEND]
Query: *#67*25#[SEND]
Divert Fax Calls
All
Set: **21*destination*13#[SEND]
Cancel: ##21*13#[SEND]
Query: *#21*13#[SEND]
No Answer
Set: **61*destination*13*nn#[SEND]
Cancel: #61*13#[SEND]
Query: *#61*13#[SEND]
Unreachable
Set: **62*destination*13#[SEND]
Cancel: #62*13#[SEND]
Query: *#62*13#[SEND]
Busy
Set: **67*destination*13#[SEND]
Cancel: ##67*13#[SEND]
Query: *#67*13#[SEND]
Divert Line 2 Calls
All
Set: **21*destination*89#[SEND]
Cancel: #21*89#[SEND]
Query: *#21*89#[SEND]
No Answer
Set: **61*destination*89*nn#[SEND]
Cancel: ##61*89#[SEND]
Query: *#61*89#[SEND]
Unreachable
Set: **62*destination*89#[SEND]
Cancel: ##62*89#[SEND]
Query: *#62*89#[SEND]
Busy
Set: **67*destination*89#[SEND]
Cancel: ##67*89#[SEND]
Query: *#67*89#[SEND]
Apr 19, 2012 | Nokia 5130 Cellular Phone
Can install Print Shop 21, but when the splash
Solution
You must reinstall Microsoft .net framework.
You can do this by:
Go to the control panel
Go to add remove program select Microsoft .netframework 1.1 and remove
Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by:
Insert the Print Shop Install disc
Double Click on My computer
Right Click on the Drive that contains the Print Shop Disc
Left click the open option.
Double click on the folder called Setup
Double click on the file that’s called 1033DotNetfx
This will reinstall the net framework on your computer and it should fix the issue you are having.
Nov 09, 2009 | Broderbund The Print Shop 21 Deluxe Full...
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 error on front load
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code f-21. Wahing machine keeps on showing code F-21 after I put it on rins/drain cycle, and 2nd spin. What should I do now?
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
Missed calls icon won't remove
Try Removing the battery and Sim card for 30 seconds
Jan 15, 2009 | RIM BlackBerry Pearl 8100
Lands Phones Logo
18 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
