Question about Maytag Refrigerators
I have a Maytag Model #PSD262LHEB refrigerator and the water comes out well and then it makes a purr noise and starts coming out very slow and thin. I've changed the filter as per the Manual and nothing. Take off the filter and put original tap and water comes out well...put back the new filter and it starts well and then slow. Could this be due a a problem with a relay going to the filter or does it necessarily have to be the water valve that has to be replaced...please help!
  • 23 Answers
1) Can you turn up the water pressure with a valve that might control the water connected to the fridge?
2) If there is a plastic water supply tube in back of the fridge you may want to disconnect it and see if there is ample water going through or try replacing it to see if it may be the problem.
Posted on Dec 25, 2013
  • catalina marquez Dec 26, 2013
    Where is it located and how do I fix this checkvalve in refrigerator?
  • Stuart Hakoun
    Stuart Hakoun Dec 27, 2013
    Pull the fridge away from the wall. See if there is a plastic flexible tubing that attaches to the back of the refrigerator and supplies it with water. Disconnect it from the fridge and place it into a bucket. This will show you how much water is getting to the refrigerator. If very little comes out of the hose then it is not the refrigerator but the amount water entering it. Then you will have to replace the tubing or somehow increase the water pressure.
4 Suggested Answers
  • 3 Answers
SOURCE: slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Posted on Jun 21, 2008
  • 400 Answers
SOURCE: Kenmore refrigerator 253.57192600 making clicking noise
It could be as simple as a bit of expansion and contraction of the wall panels or the damper which allows cooling to flow from the freezer to the fridge side.
Posted on Mar 09, 2009
jvernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
Refrigerator is louder when it turns on maytag performa side by side model psd262lheb
sometimes, as the machine starts to get a little age on them, the Freon flowing through the unit will get a little loud during the first minute or so of cycling on and for about a minute after unit cycles off. could make banging sounds, popping sounds even might sounds like water running or rain. All those sounds are normal operational sounds. I would not worry about those sounds unless you start to notice a slow temp. increase in the next few months. If you start to notice cooling issues, then I would start to get concerned about a sealed system issue.
Feb 26, 2015 | Maytag Washing Machines
Water comes out very slow
It comes out slow from the water dispenser? Model and brand please
Feb 14, 2015 | Maytag Refrigerators
Replaced water filter when trying to get water it HONKS loudly and no water comes out
You might have air in your system. Hold the dispense lever down for several second about every 10 minutes until you have the air purged.
Jan 15, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
The water dispenser in the door is making a pulsating noise. When you turn on the water in the sink it will usually stop. Our water pressure coming into the house is about 55 lbs. Maytag Model...
Just wondering if you also have an ice dispenser that noise usually means the ice dispenser is full and needs to be emptied if not sorry that is about all I have.
Feb 23, 2011 | Maytag Refrigerators
Front door dispenser
Low water pressure will cause this symptom. Make sure you have a minimum of 35 pounds pressure supplying the refrigerator with water.
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The water dispenser on our Maytag sideby side isn't working well. water comes out slow and funny noise from back of fridge
IS THERE A WATER FILTER ON UNIT....???...CHECK INCOMING WATER PRESSURE AND VOLUME AT SUPPLY TO UNIT.SADDLE VALVES DO GET PARTIALLY PLUGGED IF INCORRECTLY INSTALLED.
Aug 15, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Computer in door is making a loud popping noise,all controls are flashing thier lights
assuming this is a maytag ice and water dispensing 3 door refrig correct???? you need an new high voltage board located o back wall of your unit, without model i cannot look up for you. Happy to if you supply model. its easily replaced, but needs to be programmed to work, instructions come in kit but can be a little tricky to follow the first it me, go slow and youll get it.
Mar 20, 2008 | Refrigerators
Refrigerators Logo
130 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
