Question about Karcher PSI Electric Pressure Washer
Karcher high pressure hose pops off high pressure outlet. I think it is stripped.
  • 42 Answers
Try one of the products from your local DIY store, i,m talking about the two part putty that you mold with your fingers, can be drilled tapped and can do amazing bodges, plumbers are never without it! Good Luck - the Yeti
Posted on May 17, 2009
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Power hose keeps popping off
If it is popping off from machine side, the outlet thread could be damaged. This both on the machine and on the hose.
If it is popping out at the gun end, there must be a clip that holds it in place missing. This I am assuming that you have the right hose for the right machine. Using hoses not intended, will cause a lot of problems. Even actual hoses, they never should be modified.
Regards.
MG.
Oct 01, 2014 | Karcher K2.26 Electric Power Washer
The hose keeps popping out when you put the water on
the house end or the high pressure end?
Mar 29, 2014 | Karcher Garden
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
Apr 23, 2011 | Karcher K2.26 Electric Power Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
I have a Karcher pressure washer that leaks from the pump when operating.
could be little plastic pressure hose outlet,they can be porous and let pin holes of water through,pull plastic casing apart and remove high pressure hose outlet (black 'L' shaped pipe gun pressure hose outlet,ive repaired a couple,and machine works fine after
Oct 18, 2009 | Garden
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Jul 29, 2007 | Karcher 2500 PSI Pressure Washer
Karcher PSI Electric Pressure Washer Logo
672 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
