Question about GE GSS22JF Side by Side Refrigerator
I have a ge side by side model gss 255 gpa ss. the back panel keeps freezing
Replaced defrost heating element, worked fine for a couple weeks, now its freezing up again
  • 423 Answers
SOURCE: Refrigerator keeps freezing up. Replaced defraust
I had this problem on a Whirlpool fridge/freezer and solved the problem by replacing the temp sensor that lives inside the freezer near the coils. Here is the part you need (complete with picture)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5201204
Posted on May 14, 2009
SOURCE: GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Posted on Jun 13, 2009
aasc
  • 1606 Answers
SOURCE: GE Side by Side Freezer Side Not Defrosting
You have a bad element .
Posted on Jul 18, 2009
  • 24 Answers
SOURCE: The coils on my ge gss22wgpd bb side by side keep
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
This site has schematics of various appliances, including the model number you provided...
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS22WGPDBB&mfgModelNum=&fkMfgID=2
Your model appears very similar to mine - in the "Fresh Food Shelves" section of the above site, the sensor is diagram number 242. In the "Freezer Section", the sensors are diagram number 241 and 243.
Posted on Jul 28, 2009
aasc
  • 1606 Answers
SOURCE: My GE side by side Model # GSS20IEPA has frost on
Is the fan in the freezer working ? May have to press the light switch in to test . If not , main control board is probably bad . not the fan moter . Pull refrigerator out and remove the small 10"X13" metal cover . Unplug refrig first . Then remove the blue plug with 3 wires attached to it . The wire sequence on the plug looks like this : wire 1,wire 2,space wire 3.
Use an insulated jumper wire with both ends stripped and insert one end into wire 2 and the other into wire 3 . Plug refrig back in and look in freezer at the bottom . If the heater and defrost thermostat are good , the a red glow should appear . No red glow , either bimetal or heater is bad . Most likely heater pt# WR51X10101 . Do not forget to reinstall the blue plug with refrig unplugged or could cause main board dammage .
Posted on Aug 15, 2009
Ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
May 22, 2012 | GE Refrigerators
Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Dec 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen aide frost free refrigerator keeps freezing up.
defrost is not working so you have to check defrost timer,termination switch and heating elements could be any of these
Aug 04, 2009 | GE PSC23NHN Side by Side Refrigerator
Freezer keeps freezing up
You must change the defrost heater element, located in the back of the freezer compartment at the bottom. You have to remove the four screws, two on each side of the panel on the back wall of the freezer. The heating element located at the bottom has two wirers connected underneth on both sides of the element. The wires have female connectors which slide onto the male spades on the element, and can be easily removed. The single element heaters are now being replaced with a dual element heaters at the manufactures request. A refrigerator which I have repaired twice failed again when I replaced a single element with another single element heater after two years. I was informed only after a second trip to the same store to replace the part that General Electric suggested the dual element after they realized there were so many problems with the single element. I think G.E. should have factory recalled these units after they knew there was a problem. I also think I should not have to pay 38 dollars twice, and I should have been given the dual element the first time I had this problem!!!!!! I am a electronic and appliance technician and didn't have to pay for labor,But I am going to contacting G.E. about a refund for atleast one of my part replacements. I should been givin the dual element the first time. I recommend that anyone that reads this post that has had this problem do the same. My refrigerator was less than two years old when this problem first occured The dual element doesn't have to work as hard and will work much Longer!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 07, 2009 | General Electric GSS22JET Side by Side...
Evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Apr 29, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Defrost issues
If it's around 2-3 years old, my first guess would be the heater is bad. The GSS models have problems with the heater almost always about that time.
Test the heater and the defrost thermostat for continuity with a multimeter. Whichever one doesn't get continuity is bad and should be replaced. If they are both good and the evaporator fan is running like it should, it will be the main control board located on the back of the unit.
Click here to see the defrost heater
Click here to see the defrost thermostat
Click here to see the main control board
Let me know if you have any other questions about this issue.
Mar 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22JF Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
