Question about Valor ITS-703W Car DVD Player
Won't power up
I have checked all power and everything is good. I have hooked everything up correctly and all it will do is beep twice light up and then power off. It will repeat this over and over. What could be wrong?
Break light won't come on when I step on peddle only 3rd light fuse and lights are good
check your wires and make sure everything is hooked up and make sure all wiring is cover and not bare
Oct 12, 2012 | 1994 Cadillac DeVille
My ps3 is hooked up and everything it comes on but it won't come up on my tv screen, BUT EVERYTHING IS HOOKED UP, The hdmi cable is plugged in to
Please do the following steps to reset your PS3 display :-
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Wait for the PS3 to detect your HDMI cable.
Hope this helps and thank you for using FixYa
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
No beep sound, no display but all fan are functioning
no error beep code means, everything is good as far as the computer goes.
check the monitor, make sure the power cord is pushed in tight, there is power to the monitor,and the data connector is on correctly. if it still doen't comeup, try another monitor.
Apr 02, 2009 | Intel Motherboard
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
WONT WORK
hold down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system1.gif on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Valor ITS-703W Car DVD Player Logo
12 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
steve morris
steve morris
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
