Question about Air Hogs Havoc Heli Helicopters
Airhog Helix x4 won't hold charge - Air Hogs Havoc Heli Helicopters
I bought my grandson an AirHog Helix ion.Controller is very well made but drone was poorly made and only worked three times. I can't seem to find a replacment drone PLEASE HELP
Don't try replacing the drone, try replacing the sensor on the drone that connects to the controller. That might be why it isn't working anymore, because the sensor got damaged.
Sep 25, 2016 | Toys
I crash my airhog axes 300 x into water now it won't charge how to fix it
water and electronics do not mix
junk it and get a new one
Dec 27, 2015 | Toys
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
Changing air filter on 1996 Honda Helix CN250 @
Hi, Don for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Change Air Filter Honda Helix
Honda CN 250 Helix change air filter rols remen
Helix Service Manual contents page
https://www.partsfish.com/page/oem-parts-for-honda
Honda CN250 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 16, 2012 | 2004 Honda Helix Base
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping...
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
My parents bought a Propel RC 3-Channel Remote Control Gyropter for christmas like a month ago at JC Penney. When I tried to make it fly I noticed that the lower helix was not rotating. So I have not been...
I solved this same problem by removing the canopy and realigning the helix shaft with the motor gear. The small screwdriver provided will work. Be careful of the front white LED light when pulling the canopy off.
Dec 27, 2010 | JCPenney Gyropter RC Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Airhog helicopter
yes u can
Jan 01, 2009 | Toys
Maytag washer sav2555
the pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
Apr 06, 2008 | Maytag SAV2555A Top Load Washer
Air Hogs Havoc Heli Helicopters Logo
29 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
