Question about Kenmore Kitchen Ranges
790.9421940C burner won't shut off anybody gotta part number and what do i unscrew first to get in there and replace it
Left front burner kenmore
  • 1214 Answers
SOURCE: front left burner wont work.
It sounds like the left front control or element has a high resistance short.
Posted on Jan 24, 2009
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
heavyt15
  • 91 Answers
SOURCE: Kenmore range front left BIG burner will not work
Check infinite switch...110V one side 11ov other side
Posted on Aug 18, 2009
Jennuwine
  • 23 Answers
SOURCE: on my kenmore electic stove the burner light is
Could be an infinite switch or the clock control. What is the full model and serial number of the unit?
Posted on Sep 16, 2010
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won┬Ęt start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Kenmore 96272100 won't spin, but heat comes on....
Broken belt most likely. I looked at your model number and your belt number is 341241. Your actual model number with prefix is:
110.96272100When ordering parts you always add the 110. Anyway to replace the belt you first remove the filter. Then you must remove the 2 screws that hold the filter housing to the top because you gotta raise the top. To raise it you grab the dryers back side right behind each hinge and pull the whole top forward a bit while lifting on the front of the top to release the front portion and rotate it to the back. Then you will need a small screwdriver to assist in unplugging the door switch. Then remove 2 screw holding the front on and LIFT up the front to keep from damaging the bottom clips which are flimsy. Once the front is out of your way get the drum out and inspect the rollers. You can lube them with zoomspout oil, it is safe for appliances.
MY PICTORIAL AND VIDEO
Dec 13, 2012 | Kenmore Dryers
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Mar 03, 2009 | Kenmore Dryers
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kitchen Ranges Logo
19 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
