Question about Tablets & eReaders
Just bought a emerson EM744 tablet and the screen show 3xs everything even when chargeing it has 3 batterys like the screen is split is there a way to fix this or should I just take it back?
I fixed this triple screen issue by opening the unit (slide fingernail around the edge), then reseat the video connector, it's the largest connector, flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Posted on Jan 20, 2014
My emerson tablet em744 wont charge or turn on
Dead battery or Faulty charger?
Faulty charge port?
Jul 25, 2016 | Tablets & eReaders
My husband has a tablet that says it does not support Google CHrome or Overdrive, although he has installed OverDrive, it will not let him read from it.
It is an Emerson Tablet EM542. A good F.A.Q can be found at: http://southerntelecom.com/emersonsupport/faq_em543.html
It describes how to install .apk files for use.
Use Google Search to get other related information.
Jun 14, 2015 | Tablets & eReaders
Unlock my Emerson tablet EM744
emerson em744 factory reset instructions July 18, 2014Uncategorized
Emerson em744 factory data reset - southern telecom, Emerson em744 factory data reset if you have set a password on your tablet and forgotten the password, follow the instructions below to reset the tablet.
How to hard reset emerson tablet? - the tablet has a, My girl locked her emerson tablet how do i unlock it.. foegot password emerson 543? would like to hard reset my tablet videocon vt75c. i had tried the options.
Where is the operating manual for emerson tablet mmem 744, How do i hard reset my emerson tablet em744? i had my ereson m744 connected to the pc to charge and when i unplugged it, it was locked. i have not established a. How to reset an lcd tv ' ehow, Navigate to the "factory reset" or similar wording option using the arrow keys on your tv's remote control or on the front panel of the tv. press the "ok" or "enter.
Gsistore.com, (2) 04a42-015b-05 120v 4" bracket only (2) 405-043a 120v 4" blade only (2) 501-138b 120v 4" motor only 02a42-009a lock strike for sm models 02b01-085d door assembly.
How to connect wireless headphones to a pc ' ehow, Test the headphones. pick out a song or a video and play it on your pc. connect your wireless headphones and verify that you can hear the audio..
5 home depot hacks - buzzfeed, 5 home depot hacks. home depot may not have swedish meatballs, but it can be the ultimate store for affordable, durable, modern furniture if you know how to hack it..
Amana top load washer service manual - scribd, This base manual covers new double front panel series, top load wash machines. refer to individual technical sheet for specific information on models..
Stirling engine design manual - scribd, Stirling engine design manual 2nd edition this design manual provides an introduction to the stirling cycle heat engines. it analyzes compares non proprietary engine.
Mar 29, 2015 | Tablets & eReaders
Frozen screen on emerson tablet em744
Press the reset button with pin - its usually a small hole with reset under it.
May 12, 2014 | Tablets & eReaders
How to reset an emerson em744 tablet?
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 25, 2014 | Tablets & eReaders
How to unlock Emerson Tablet EM744 with pattern password
You may have to remove the battery for about 30 to 45 seconds and this may reset and delete the password. Remember, this doesn't always work and these are sensitive and you need to remember your patterm lock. So make it something that is easy to remember, like a password.
Dec 14, 2013 | Tablets & eReaders
Screen wont unlock em744
There is a small hole in the back of your tablet with an "R" or "Reset" next to it. Put a paperclip into the hole and hold it down for half a minute, it should give a little as you are pressing a button inside the hole. When you turn the screen over you will either see only a blank screen or the word "Emerson". That is the tablet going through the shutdown process don't be concerned if you see either as the word only stays on for a short time. Let the tablet sit for 3 or 4 minutes then try to power it back on by holding down the power button. You should see a screen after a few seconds that says "Emerson" that will have a rotating partial circle under it. This should complete your reset. If this doesn't work then you are most likely having a hardware or firmware problem and need to take the tablet back to your place of purchase for support.
Dec 01, 2013 | Tablets & eReaders
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Tablets & eReaders Logo
257 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
