Question about Kenwood Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
I have a Kenwood KX-79 CW dual cassette and cannot locate a users manual. Does anyone know how to hook it up to the amp. The out slots for the deck are line in and out Record and Play. The Amp has slots for Tape 1 Record and play; Tape 2 record and play. Don't understand how Tape 2 is hooked up since there's only one in and out on the tape cassette player.
  • Kenwood Master
  • 5,056 Answers
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Posted on Apr 29, 2014
robotek
  • 1512 Answers
SOURCE: Tascam 202 Mk111
most all twin well machines will play off one deck and record to the other.
using an outboard mic preamp will allow for less noise using the sm57. balanced mic cable with 3 pin xlr/cannon connections also reduce noise.
Posted on Dec 09, 2007
  • 10 Answers
SOURCE: Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Posted on Apr 17, 2009
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
djtatty
  • 417 Answers
SOURCE: Need to find user manual.
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Posted on Mar 01, 2011
eliezerpenny
  • 236 Answers
SOURCE: Tascam 322 dual tape deck. Tape 2 just stops.
Probably.
Does the motor still turn?
Posted on Nov 12, 2012
Kenwood kx-w6050 dual cassette deck. play, rewind n forward got problems? Whats seem the problem to be?
It needs servicing by a Technician- often times say it only needs belt but you can replace belts and still have the same problem. The dried lub has to be removed and new fresh non- degrading grease needs to go in and then it will work. Dual cassette decks are usually not worth the $200 it will take to work on two mechanisms. You might find a $10/Hr technician but I doubt it.
Aug 07, 2015 | Kenwood Audio Players & Recorders
KENWOOD KX56W/CW
I have a KX-56W. I can get the user manual for you if you still need it
Jul 02, 2013 | Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
189 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
