Question about Toshiba Computers & Internet
Enable Bluetooth on Toshiba - Toshiba Computers & Internet
    Master:
  • Toshiba Master
  • 788 Answers
Please check the driver and also check if there is a software to assist enabling your Toshiba bluetooth (certain model) here:
http://support.toshiba.com/drivers
Posted on Dec 25, 2013
A665-s6094
Yes and no...Yes, you can add this module:
  • Part Number PA3710U-1BTM
  • Description: Toshiba Bluetooth 2.1+EDR USB Nano Adapter
This will enable bluetooth functionality...There are drivers for the bluetooth stack on the support website:
Satellite A665 S6094 Support Toshiba
But no, bluetooth is not built in...
May 25, 2014 | Toshiba Satellite A135 Notebook
Satellite c55-a5308 bluetooth enable
search for switch or button to activate wireless on your device. Have you verified that the Bluetooth radio is turned on? If the radio is off, then nothing may show in Device Manager. Look under Network Cards - unless your BT radio exposes a PAN (personal area network), you won't find anything there. You need to look under the "Bluetooth Radios" section.
Jan 17, 2014 | Toshiba Satellite A135-S4527 Notebook
Enable bluetooth on c55-a5308 satellite
On the laptop you should fine a way to enable blue-tooth. usually there is a button close to the power button across the top. Alternately, you can do so from control panel too.First you need WinXP SP2 or higher version of OS.Go into the control panel, double click on bluetooth, in there, there is a setting for "Turn Discovery On". Put a tick in that box and then try pairing the laptop with any other device
Jan 17, 2014 | Toshiba Satellite Computers & Internet
How to enable my bluetooth on my toshiba laptop
Most of the time when you go to Start - All Programs - Toshiba you will see Bluetooth. This will be there if you have the driver installed. Also, make sure that the Bluetooth logo is on the bottom of the laptop to make sure that your model was built with the Bluetooth chip in it. Sometimes you can also find the bluetooth icon on your taskbar and by right clicking on it you will bring up the "enable" option. You may also want to go into your control panel and see if the icon is in there. The shortcut to get to the control panel is "Start" key then press the "c" key. Hope this helps.
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Bluetooth config
You can enable it by hitting your windows button on the bottom left of your keyboard and then hitting control panel. From there, go the the blue icon that says bluetooth.
Sep 21, 2009 | Computers & Internet
Not able to connect to BT Homehub wireless Toshiba Satellite Pro
  1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, and then double-click Bluetooth Devices.
  2. Click the device that you want to change, and then click Properties.
  3. Do any of the following:
    • To change the name of the device, click the General tab, type a new name, and then click OK.
    • To enable a service, click the Services tab, select the check box next to the service, and then click OK.
    • To disable a service, click the Services tab, clear the check box next to the service, and then click OK.
    • To make your computer discoverable to Bluetooth enabled devices, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to find this computer check box.
    • To make Bluetooth enabled devices discoverable to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to connect to this computer check box.
    • To be notified when a Bluetooth enabled device wants to connect to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Alert me when a new Bluetooth device wants to connect check box.
    Warning
    • To help protect your computer, only make your computer discoverable when you want a Bluetooth enabled device to find your computer.
Some computer programs require a COM port (also called a serial port) to communicate with a Bluetooth enabled device. For example:
  • A program that synchronizes contacts with a mobile phone
  • A program that extracts Global Positioning System (GPS) coordinates from a GPS receiver
When you use the Add Bluetooth Device Wizard to add a Bluetooth enabled device to your computer, you create an incoming COM port, which permits your device to connect to a program on your computer, and an outgoing COM port, which permits a program on your computer to connect to your device. Usually, you only need to use one of these COM ports.
To decide which COM port to use, you can check the information that came with the program or your Bluetooth enabled device, or go to the manufacturer’s website.
If you're still not sure which COM port to use, try each COM port, one at a time, and use the one that successfully allows the program and your device to communicate.
Mar 31, 2009 | Toshiba Satellite Pro L300 Notebook
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Hi!i have a toshiba satellite A135-S4527 laptop but i don't know if it has bluetooth or not.
There should be a bluetooth key on the on the keyboard to enable it. If there isn't one, check for bluetooth drivers in the control panel to see how to enable it or to verify the hardware.
Aug 06, 2008 | Computers & Internet
Blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Jun 14, 2008 | Computers & Internet
Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Sep 11, 2005 | Toshiba e400 Pocket PC
Computers & Internet Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
