Question about Syntax Olevia 527-S11 Television
Unable to setup input for tuner and auto program
Cant scan me hittach tv only get one channel with antiner
if the signal level is low enough it will not auto program it and will by pass it in the auto program mode . or you have antenna problems or possibly a tuner problem
Oct 19, 2014 | Televison & Video
Need help to get coby tv to work
The basics here: with the original remote enter the menu and look for setup or auto program, select either CABLE OR AIR (WHICHEVER IS YOUR SIGNAL SOURCE) and run the auto program.
You should also be able to direct enter channels like 06 enter to manually go to a channel.
Lastly if you can hook the signal via a box to the rear inputs you can bypass the tuner in the set and see if it works that way.
if questions/comments press the "make a comment" button on this page.
Mar 25, 2012 | Coby Televison & Video
My 32LG3000 is flashing 'Not Programmed' Have done auto tuning option and get message 'can't find any valid channel-Check antennae and run auto tune again' TV is connected to a sky...
Try changing the source from the tuner, which is not programmed, to "video 1" or whatever the input for your Sky HD Box is plugged into. I would suppose as soon as you change the input method to not be your tuner, this error will go away.
May 06, 2011 | Televison & Video
I have a marantz sr7200 receiver and i am unable to get sound when its in DSS mode. The sound works in dvd and tuner modes.
In the setup menu, did you set up the input assignments for DSS to be the correct digital input or analog?
Feb 25, 2011 | Marantz Audio Players & Recorders
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Only the analog inputs work after my electric service meter was replaced by the power company. The optical and other digital inputs are now dead. only cd and tape and tuner now work. any suggestions?
Chances are your receiver "defaulted" to original programming due to loss of power. Go to the receiver's menu or setup and get into audio or input setup. It should give you the choice of "analog" "digital" maybe "PCM" or "Bitstream" hopefully "Auto" choose "Auto if present or "Digital". That should solve your problem. Depending on your receiver type, you may have to repeat this for each input. Hope this helps
Jul 07, 2009 | Audio Players & Recorders
Cant get channels to program manual or auto
Try the STANDAR mode search, instead of AUTO mode, also try IRC mode, and HDR more, maybe thats why you dont get any channel...
Mar 19, 2009 | Olevia 227-S11 27 in. LCD TV
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
Syntax Olevia 527-S11 Television Logo
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
