Question about Canon Pixma MX452
Printer not recognized during initial installation
    Problem Solver:
  • 21 Answers
Need to install the drivers first, prior to connect the printer. remove all the connection and try.
Posted on Dec 26, 2013
How can i use my 881 sierra wireless aircard to get online with my ps3
Download and install Sprint's SmartView. Select the download for your computer's operating system. Follow the installation wizard's prompts to properly install SmartView. The aircard should be connected to the computer during installation.
Restart the computer. Leave the aircard connected during the restart.
Double-click on the Sprint SmartView icon on the desktop.
Wait for the program to initialize and recognize the aircard, then click "Connect." Sprint SmartView should activate the aircard automatically.
Open a browser window to access the Internet.
Feb 04, 2011 | GoAmerica Sierra AirCard 300
Hi lexmark. we have basic lexmark printr/scannr -- model# 4690 --- The desktop pc which initially took the lexmark CD for config. is currently off site being repaired. OUR QUESTION IS.., well,we are ...
You will have to install the printer driver software on the other computer.
During install it should ask if the printer is a network printer or direct conncected -- click network connection.
You should be able to download the software package at Lexmark's website.
Jan 10, 2011 | Lexmark X4650 InkJet Printer
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
Initialization flash simm memory on LJ4+
You don't have to initialize the extra memory on that printer. Just install it and when you power on the printer it will recognize the extra memory. If you mean install, then go to www.HP.com and look at the instruction manual in the support section. I believe you have to extract the formatter board from the rear and then you should see the place where the chips should go.
Apr 09, 2009 | HP LaserJet 4 plus Printer
Memory won't initialize on a HP Laserjet 2605DN
I found this page in the User Guide. Maybe it will be helpful.
"If the printer has a new memory DIMM installed, all Windows users of the printer must set the printer driver to recognize the newly added memory. Macintosh computers automatically recognize new memory.
To enable memory for Windows
1. On the Start menu, point to Settings, and click Printers or Printers and Faxes.
2. Select this printer and select Properties.
3. On the Configure tab, click More.
4. In the Total Memory field, type the total amount of memory that is now installed.
5. Click OK."
Give this a try and if it doesn't work, let me know and I'll keep looking.
Feb 18, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
1700 printer
How did you install the printer?
I have found that if you just let your computer recognise new hardware, it really has a hard time with the USB printing to the 1700's.
Originally there was a disk that came with the 1700 printer. You do want to use that.
During the install, you run the software, and then turn on the printer. (You can have the printer on during the install, but ignore the Windows Wizards that come up).
If you don't have the original 1700 install disk, you can download it from Dell.
The problem is with USB port configuration. These little 1700's are just a pain sometimes if not installed the way they were originally designed.
Jul 31, 2008 | Dell 1700n Laser Printer
Initial installation doesn't work
Hi, check yr printer driver if it's ok then check photoshop install ok. or not.
Apr 01, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Canon Pixma MX452 Logo
old marine
old marine
