Question about Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd
Unable to access any set-up in the menu.
I followed directions in the original set up of the camera. I want to change some sound settings. Can't access any set up options. They just aren't there.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 166 Answers
Upgrade the firmware?
Posted on May 25, 2014
4 Suggested Answers
SOURCE: D40X: can't access menu with card in camera
Try "Custom Settings Menu" -> "06 No memory card?".
Does it have any influence?
Tom
Posted on Aug 24, 2008
SOURCE: Wrong batteries settings prevents access to menu
Charge fully the batteries you have, to prevents the camera distinguish the type of batteries (maybe the camera senses the charge), turn on the camera and you will have access to the menu to set up the batteries type correctly, that´s all.
Posted on May 05, 2009
  • 11967 Answers
SOURCE: How to get camera back to original settings?
Go into the menu and find "reset"..follow the on-screen instructions.
Posted on Jun 14, 2010
Set-up my new Nikon Coolpix P520. Now want to change sound and review settings and can't access set-up choices
Look in what part of the menu you are. If you are in Automatic scene or effects, you only can change few things. Only when you select P,S,A,M or U, you can set lots of things in he menu. Please look in the manual, because on your camera are so many things you can set, if in the correct menu or in the right settings menu.
Dec 25, 2013 | Nikon Coolpix P520 Camera - Silver 18.1Mp,...
Following the instruction manual, I'm unable to access the setup menu, just how the &^%$ do you enter setup?
Press the menu/set button...see the icons on the left?....see the wrench at the bottom?...scroll to that and you are in the setup menu.
Jan 22, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
I have changed the settings somehow on my camera and don't know how to get it back to it's original setting, the quality of my photo's seem quite ***** like and very bright.. anyone know how to change it...
Press the MENU button to bring up the Record mode Menu. You can use this shortcut menu to quickly change image resolution, reset all settings to factor defaults, enter Panorama mode, enable Picture+Sounds, enable Silent mode, change the scene mode (when set to the SCN position on the mode dial) as well as enter the Setup menu.
Hope this helps.
Jan 12, 2010 | Olympus FE-230 Digital Camera
Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Sep 24, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When i turn on my camera the lens goes in and out but it wont let
Hello!
First, check if the Battery inserted in the Camera is fully charged. If not then charge the Battery to its fullest then insert it in the Camera to check its operation.
Next, remove the Battery from the Camera then press and hold the Power button for 30 seconds. Then, reinsert the Battery pack in the Camera and turn it ON and check its operation.
Finally, please check if the menu screen is accessible by pressing the menu button directly or while reviewing the captured images. If the menu screen is accessible then reset the Camera to the original factory settings.
(a) Please press the menu button directly or while reviewing the images to access the menu screen.
(b) Then, press the right arrow on the control button to select Setup option.
(c) Next, use left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" and OK.
(e) Finally, follow the on-screen instructions to set the clock on the Camera.
performing all the above steps will reset the Camera to the original factory settings.
If, even after performing all the above steps, the issue persists then the issue is related to hardware malfunctioning and service will be required.
Aug 21, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dsc-w40 when turn on the word access and lens goes in and out
Please remove the Battery from the Camera then reinsert it after three minutes. Please make sure that the Battery is fully charged. If menu options are accessible then reset the Camera to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings.
(i) Turn ON the Camera.
(ii) Press the Menu button on the Camera to display the menu options.
(iii) Then use the control button on the Camera to the select the Setup option.
(iv) Next, select the Setup 1 option then "Initialize".
If the issue persists even after resetting the Camera to the original factory settings then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Dec 28, 2008 | Olympus Stylus 850SW Digital Camera
Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd Logo
37 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
