Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
My oven is a GE XL44 #JGBS07PEA2WW
I Have replaced the safety control valve but no gas goes to the oven. The igniter comes on but no gas
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Oven won't heat
On maytag units (household)you will need an Amp probe to see if your ignitor is working properly..yes it maybe glowing but it does not mean it is ok..the valve opens on the amp draw of the glow bar it should read a min of 3.2 to a max of 5.2 amps at full glow if you read in that range your valve is bad if not replace your ignit.
Posted on Feb 20, 2008
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
oldTech2332
  • 2341 Answers
SOURCE: IGNITER GLOWS BUT NO GAS GETS TO THE BURNER. WHILE
Hello John,
Having replaced the ignitor and the gas valve having continuity the problem has be the gas safety valve bimetal is stuck. The only thing you check is amprage draw on ignitor it should be between 3.2-3.6 (as label on gas valve states) with a new ignitor and again continuty on gas valve its the gas valve its stuck and wont open.
Good luck,
Gene
Posted on Aug 09, 2011
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Maytag gas oven wont restart after pre heat
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Xl44 gas
two things either hte clock(control ) assy not sending powerdown to the igiotr, or hte valve that the ignitor is connected to onst nay good, unplugh the unit andwitha meter try testing the 2 wire connections on the top of the safety valve( i wire goes to the ignitor nad the other is a neutral wire htt hooks downt to under the valve for the broiler, you should show continuity across those to leads, if not your valve is no good and will need replacing
Mar 20, 2008 | GE JGRP17 Gas Single Oven
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
