Yamaha htr 5790 wont power up. makes a click noise, no power.
dunnbiker
  • 8546 Answers
SOURCE: How do you hook up
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Posted on Dec 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a yamaha htr-6130
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 29, 2011
kerguney
  • 577 Answers
SOURCE: where is the rca auxilliary
On the back of the Receiver plenty of "RCA inputs" ..you can use any of it except
"Phone /turntable" input and than select it from control knob the relevant input..
Take care and pls remember to rate me..
Thanks
Posted on Jun 18, 2011
simplemitch
  • 752 Answers
SOURCE: I need to know how
See the answer I provided the first time you posted this....
Posted on Jul 03, 2011
simplemitch
  • 752 Answers
SOURCE: How do i connect 901
Let's try this for a third time. Bose AMP OUT to Yamaha MD/TAPE IN.
Bose AMP IN to Yamaha MD/TAPE OUT.
Please rate this solution.
Posted on Jul 04, 2011
Where is the rca auxilliary input on the yamaha htr-5790. i want to hook up my ipod
Thanks
Jun 18, 2011 | Yamaha HTR-5790 Receiver
Were can I find a remote for htr 5790?
The remote for your unit is the RAV-238. You can purchase a replacement here:
http://remotes.com/store/yamaha/rav238.html
Feb 28, 2011 | Yamaha HTR-5790 Receiver
HTR 5790 will not turn on. There was a loud pop (which I am guessing is the fuse?) and than the rec went out.
there is a post to this already about checking your voltage inside the unit on the back right hand side and how that is done. my guess is your system is set up with all your other devices hooked into one wall outlet and you overloaded it. Or maybe used a ext amplifier to increase your wattage. IF you try out holding down the ABCD method as described and press input? it may overide the factory setting when the unit experience any type of power malfunction.
Aug 26, 2010 | Yamaha HTR-5790 Receiver
My receiver won't turn on. All I get is a fast
I am sure you have tried and disconnecting all the speakers and taking the unit to another outlet right? If it works you fried your surge and need to replace it. Otherwise the unit went into that strange power protection mode
Jul 05, 2010 | Yamaha HTR-5790 Receiver
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
HTR 5790
Yes, you would need an iPod to RCA Cable that will connect to your iPod and to the RCA Auxilliary input of the Yamaha HTR-5790 7.1 Channels Receiver. Similar to a Cygnett Groove Transit - MP3 Phone to RCA Stereo Cable or an iPod to RCA Retractable Cable.
Good luck and kind regards.
Nov 25, 2007 | Yamaha HTR-5790 Receiver
Powers on for just 5 seconds then off
Took my Yamaha HTR 5790 to a repair shop for an estimate to repair. Cost me $50 for estimate to be applied to repair. It needed two circuit boards replaced at a cost of $390.00.
SOLUTION... they kept my $50 and I bought a new AV Receiver that WAS NOT a Yamaha.
Aug 23, 2007 | Yamaha HTR-5790 Receiver
HTR-5790 shut off problem
WOW this worked.. Hold down the ABCDE and the preset tuning right arrow and then hit power.. It puts it into a diagnostic mode, but it stays on.. I just rerouted my video to not use the receiver  and the audio works perfectly now.
Nov 26, 2006 | Yamaha HTR-5790 Receiver
22 people viewed this question
 Grubhead
Grubhead
