This telescope works by a mirror. The image is upside down, sorry.
However you might want to get a Telescope USB camera, then you can see the image on your PC the right way up.
Yes, all astronomical telescopes show upside down images--- no up or down in outer space-- and you would need more lenses in the light path to erect the image.
Read my frequently asked questions tip on my profile page. Your question is asked just about every day by beginner amateur astronomers.
Is your scope like the picture? If it is it is a REFLECTOR style with a mirror on the bottom.
Put the eyepiece into the focuser-- this is the UP end of the telescope. The large mirror is on the DOWN end. I have seen many beginners mount these upside down with the open end pointing at the ground!
Yes, but it will probably cost almost as much as you paid for the scope:
here is one: http://www.amazon.com/Celestron-Erect-Refractor-Schmidt-Cassegrain/dp/B0000665V4/ref=sr_1_2?ie=UTF8&s=electronics&qid=1283197941&sr=8-2
All astronomical telescopes show upside down images, it's normal. The erecting diagonal is only used for terrestrial day time viewing, of land objects.
All astronomical telescopes show upside down images. It's completely normal. Nothing is wrong with the scope. For terrestril viewing you can buy an "erecting prism diagonal" which will turn the images right side up.
Like this: http://www.skiesunlimited.net/index.php?CategoryID=98
Hi, this is a common "problem" for astronomical telescopes. Same with my Meade 3" refractor and spotter. It is actually a design 'feature' not broken.
The issue is that most astronomical telescopes naturally show images upside down, or some combination of upside down and left-right. (Astronomers usually don't care, because space has no up or down.) It is just the way optics work when lenses or mirrors bounce and bend light. (And since the professional astronomer wants the most light and most direct image, they usually don't want extra devices just to make it right-side up.)
Reason that binoculars don't do that , is they employ special internal prisms to get the image back right-side up.
Easiest solution for astronomical telescope is to buy what is called a "star-diagonal" or "image-erector prism". These will usually make the image look normal for us earth-based folks.
I do not know what exact type your Meade 227 telescope is, but the spotter scope is most likely a simple refractor. So it MAY be possible to install a star diagonal onto it. Or might not. Depends on the exact spotter scope design. Another option may be able to buy a replacement spotter scope that is designed for correcting image orientation.
