Question about Sony Bravia KLV 32V300A Multisystem LCD TV
Sony 32v300 lcd
Snow in the center sides having vertical coloured lines with white background
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
SOURCE: Vertical dark line down screen
http://www.avforums.com/forums/sony-owners-forum/1165140-faint-lines-kdl32s5500.html
I have also experienced the same problem on two occasions, but my Sony TV KDLV3000 has actually been backwards and forwards on three occasions to be repaired. I have had a new control unit and will be having a second screen replacement shortlymad.gif. I have contacted my local Sony Centre and they have stated that they will only replace the TV if there are THREE IDENTICAL faultsfacepalm.gif.
COME ON SONY CENTRE GET YOUR ACT TOGETHER AND TAKE A NOTE FROM JOHN LEWIS THERE CUSTOMER CARE IS SECOND TO NONE.
Not sure I'll buy a Sony again after this experience having been a loyal Sony customer for a number of years, will probably look at a Samsung or LG next time.
Posted on Jan 20, 2010
Testimonial: "Thanks for your comments. Very useful."
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Posted on Jan 29, 2010
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
PSP White vertical lines
can u help me to hoe the psp opeat
Oct 26, 2008 | Sony PlayStation Portable (PSP) Console
Vertical Line
could be the logic board, but , unfortunately, more likely the lcd panel itself. very unlikely to be economically repaired. new panel and labor a few hundred $'s less than new tv
May 24, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KLV 32V300A Multisystem LCD TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
