Question about Dryers
Dryer wont turn on, I reset main breaker but the dryer still will not turn on and run
The dryer wont run, I reset the main breaker but it still wont turn on
  • 42 Answers
Overheat thermostate is located inside the machine, there may be a serious fault with or short with the heating element,. Good Luck - the Yeti
Posted on May 17, 2009
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Hi, I turned off my house's main switch while the dryer cycle was going on. Now the dryer doesn't turned on after the power is back. Do I need some type of reset to get it turned on?
Check the circuit breaker for the dryer itself, one side of it may have tripped. Turn the dryer's breaker off, wait a moment, then turn it back on.
If the dryer was in the middle of a heating cycle, rather than a cool down cycle, then the heat coming off the element may have caused the thermal switch in the dryer to open since the fan / blower wasn't running. Usually, this switch will reset itself, but not all will.
Removing the back panel of the dryer, with the power cord UNPLUGGED and breaker TURNED OFF (Just in case), you should see 1 or 2 limit switches. They will likely appear to have brown or dark housings, and will be round or slighly diamond shaped. Use a multimeter to check for continuity across the switch. If the dryer is cold, you should have continuity. If you don't have continuity, then replace the thermal switch.
Feb 13, 2011 | LG Dryers
I blew a fuse last night and had to reset the breaker....I went to dry clothes this morning and the dryer is dead, wont come back on after being plugged and unplugged. I reset the circuit breaker too and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont turn on
Howdy: The main electric motor has a built in circuit breaker. Check to see if it needs reset. If it did blow then something else is the trouble.
The start button (switch) turns on the motor which starts the drum and
turns on the ignitor to start the element for heat. Need more info after you check the motor. It also could be the on/off switch - Good luck - Doug
Dec 09, 2009 | Kenmore 63942 Dryer
Is there a reset button after heating up and
Not sure about your model.
Look on the motor, sometimes there is a reset button on the motor.
Sep 25, 2009 | Whirlpool LER4634J Electric Dryer
Is there a reset button on a kitchen aid electric dryer...appears to have over heated and I just cleaned it up. Can I just press a reset button? If so,where is it? EastsideRose
There is no resettable fuse on this model dryer I hate to say. If the thermal fuse blew out, you wont get heat, but dryer will run. If dryer doesnt run at all, you will have to remove the back (if your model # is right) and replace the thermal FUSE (not cutoff). Three screws on either side of the back, three at the top near where the pigtail goes in. You will see a small white fuse with two wires going into it. Very easy to fix, and part very inexpensive.
Jun 11, 2009 | Whirlpool LEN2000PW Dryer
Breaker was inadvertantly tripped by person which shut dryer off when reset breaker dryer wont work
You have to test the voltage to verify that the breaker did reset. Unplug the dryer, and verify that you have 240 volts at the receptacle
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Dryer wont turn on?
check your outlet for power, or reset your breakers, if it doesn't start please re-post an be a lil more specific on what the machine did or didn't do last time you had it running if you noticed something?
May 26, 2009 | Kenmore Dryers
Dryer trips house circuit breakers when I turn it on.
Hello rarakaki,
I assume that you are referring to an electric dryer and that when you run it, it trips the main house breaker. If that is correct, then you may be running too many appliances simultaneously and that will draw curent , beyond the maximum rated value of your house main breaker. It is also possible that your main breaker may be going bad and tripping below it rated current value. I suggest you do the following: Shut off other appliances or electrical equipment in other rooms and then try running your dryer. If it operates and does not trip the main breaker , then the comments stated above are the problem. You may need to have an electrician replace your main breaker and/or change your service to a higher value. Please get back to me if I am incorrect in understanding your problem. Regards,
Rick
Dec 18, 2008 | Whirlpool Dryers
GE Dryer DBL333EAOWW
Did the Dryer work before? What led to this problem? Most Electric dryers work on 240 Volts. And have their own seperate circuit breaker, usually marked as "Dryer." So resetting just the main cuircuit breaker might not be enough. Did you reset the Dryer C. breaker?
Sep 22, 2007 | Dryers
Dryers Logo
248 people viewed this question
Top Dryers Experts
