Question about GE JBP71 Electric Kitchen Range
Flashing F3 error code - GE JBP25G
This happened one time a month ago. Now it's happening more frequently. The oven will bake for an hour or two, then goes off and I get the F3 code. If I reset the breaker, it fixes the problem until next time the oven is used.
  • foruminfo May 19, 2009
    Is this something that is easy to fix? That is, would you recommend a repair person fix this, or can this be a do-it-yourself project?
  • 42 Answers
Faulty thermostatic switch or regulator. Sometimes there is a heat sensitive bulb of gas that then opens or closes a switch or connects to a sender, i suspect the fault lies with one of these, telephone the helpline , try and find out if this is a common problem. Good Luck - the Yeti
Posted on May 17, 2009
  • Yetimagic May 19, 2009
    Yes im afraid you will need someone in to do it if your not technically minded, all parts can be ordered from the net though, so if you can get someone to show you the bit thats faulty then you could order it yourself and fit it. Maybe its time to start again eh and get a newer or one that works second hand, a call out may cost you £50.oo, so is it worth it? All the best the Yeti
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
WHen I start to bake I get an F3 error
We have a GE slide in oven JSP34. F3 came up while baking. I called the 1 800 number for GE and was told I needed a new over sensor. I ordered it and it arrived and had a local appliance person install it. Seems to work fine.
May 15, 2010 | GE JSP69 Electric Kitchen Range
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Dec 16, 2007 | GE Spectra JBP78 Electric Kitchen Range
Oven trouble
I don't have a solution for you but I have the same problem and no owner's manual to refer to. This site won't let me post a new problem.
Nov 15, 2007 | Kenmore 46564 / 46565 / 465 / 6646569...
Open Questions:
GE JBP71 Electric Kitchen Range Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
