Question about Panasonic DMR-ES10 DVD Recorder
Panasonic Model DMR-48EZ, not reading disc - Panasonic DMR-ES10 DVD Recorder
  • 11 Answers
SOURCE: dvd noread
If you put a disk in and it just clicks several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. My own theory is that when you record in the high speed mode, it is just too much for the spindle motor to handle over time. I keep my record speed in the standard mode to play it safe.
Posted on Apr 09, 2008
Shuttle83
  • 1139 Answers
SOURCE: Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 16, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
SOURCE: DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
Posted on Jan 01, 2010
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Tip
PANISONIC DMR-E75V NOT READING BLANK DISC
I HAVE A PANISONIC DMR-E75V AND WAS HAVING PROBLEMS BLANK DISC READING. I UNPLUGGED UNIT FOR A COUPLE OF MINUTES PLUGGED IT BACK IN AND IT WORKED FINE
on Mar 19, 2009 | Panasonic DMR-E75V DVD Player/VCR
My panasonic model dmr-es20deb will not read discs
Clean the Disc Lens with a good Lens Cleaner !
Feb 17, 2010 | Panasonic DMRES15 DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
    Will my non finalzied discs play on a panasonic ez 28 or ex 768
    You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
    Cheers...
    Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
    This is the most common problem, in most cases the burner must be replaced.
    May 03, 2017 | Panasonic DMR-E80H DVD Recorder
    DMR-EH75V DVD Recorder
    ekimt,
    Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
    mjs8
    Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
    Panasonic dmr-es45v
    The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
    Jan 15, 2008 | Panasonic (DMR-ES45VS)
    Panasonic DMR-E50 won't recognise blank DVD's only
    You can only record to dvd-ram or dvd-r NOT dvd-rw!
    Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
    Panasonic DMR-ES10 DVD Recorder Logo
    66 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
