Question about Soundbest International Garden
Changing clutch on Stihl hs45
How do I get to the clutch to change it and is fixed by left hand thread?
  • 625 Answers
SOURCE: fan clutch removal
crank the engine and see wich way the fan turns and that's the way to loose it if turns to rt it looses to rt if to the left it looses to the left
Posted on May 28, 2008
  • 11 Answers
SOURCE: Remove Fan clutch from water pump? Left or right hand threads?
left
Posted on Jun 19, 2008
GARYca
  • 672 Answers
SOURCE: Fan clutch removal
the four bolts holding the fan clutch to the water pump pulley are loosened counter clockwise. If you don't have a pulley holding tool at hand, use a wrench(closed end side) as a locking leverage on the studs(do not place the wrench on the nuts) while loosening the nuts 1 by 1 with another wrench. When reinstalling use the same method, but place black elec tape over the studs(prevent thread damage) after you hand tighten the bolts for the fan clutch. hopefully this helps
Posted on Jul 20, 2009
dontbother10
  • 2220 Answers
SOURCE: Stihl ms 290 chainsaw. Clutch oil pump is this
The oil pump is behind the clutch drum. The drum is a left handed thread. HTH
Lou
Posted on Sep 09, 2009
  • 86 Answers
SOURCE: removing clutch basket nut
undo anti clockwise.
Posted on Mar 10, 2010
What is the torque specs for the clutch on a stihl 170 chain saw
There is no spec as such although Stihl will probably argue differently. Because the clutch goes on as left handed thread the direction of the motor running means it will tighten the clutch to a suitable torq when the tool is used.
Apr 30, 2015 | Stihl Garden
How to repair clutch HS45 Stihl
I'm not familiar with your machine, BUT... most of those centrifugal clutches ARE NOT repairable, and must be replaced when failed.
Jun 11, 2014 | RTO Weed Eater Hedge Trimmer 20cc,...
I need to replace the clutch that is screwed on to the end of the crankshaft on my Stihl HS 45 Hedge Trimmer. How do I get the old clutch off of the crank?
Remove the plug and insert a length of old pull cord into the hole, makin sure to leave some to pull it out with. Also making sure the piston is at bdc, you turn the clutch counter clockwise
Oct 26, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Need to know torque specs for crankshaft and tranny input shaft when changing stator...
Clutch hub nut, left-hand thread, couple drops 262 loctite (red) to last few threads, 70 - 80 ft-lbs.
Crankshaft nut, right-hand thread, couple drops 262 loctite (red) to last few threads, 150 - 165 ft-lbs.
Sep 13, 2013 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Chainsawsw
the clutch assembly is held on with left hand threads i use a dull air chisel and hammer it loose
Sep 09, 2012 | Stihl Garden
How do i remove the clutch from a ts 410
It should be threaded to the crank. On the end of the clutch it is hex shaped. I always used a metric socket and impact to pop them off. I am pretty sure they are left hand thread and there should be marked with "off" and an arrow showing this.
Jul 02, 2012 | Stihl Ts 410 420 Cut Off Saw...
How do you remove the clutch assembly on a Stihl 5200 chainsaw please?
Hi, you need to buy a piston stop from a stihl shop to lock the piston then undo the clutch with a 19mm deep style socket, it is a left hand thread, regards Phil.
Jun 03, 2012 | Stihl Garden
The automatic oiler on my sthil ms 390 is not working, the oil is running out of the front under the muffler instead of oiling the chain how do i fix this?
If I had an IPL we would attempt a repair but I do not, and Stihl IPLS are proprietary.
I am going to recommend you do search here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did for "Stihl MS390 Oiler" and found many threads. This being one of the best although it does not address your exact problem.
THALL10326 and Lakeside are both Stihl mechanics. You will find them most helpful.
http://www.arboristsite.com/showthread.php?t=65495&highlight=stihl+ms390+oiler
If you do not find an answer please post your problem there. Someone there has seen and repaired what you have. I think the oil pump or connector has failed. Both are behind the inboard clutch. If internal clutch parts must be removed they have a left handed thread (tighten to remove). HTH
Lou
Jan 14, 2010 | Garden
Stihl ms 290 chainsaw. Clutch oil pump is this left hand thread?
Lou
Sep 09, 2009 | Garden
Garden Logo
563 people viewed this question
Top Soundbest International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Soundbest International Garden Expert? Answer questions, earn points and help others
