Question about ASUS Televison & Video
Delta Electronics ac/dc adaptor model adp 90sb BB
My Asus A8jp Laptop ''died''. The Delta Electronics ac/dc adaptor model adp 90sb BB was red hot and was making a beeping sound and it's green light was blinking. When I unplugged the adaptor from my computer, but left it plugged into the wall the sound went away and the green light stopped blinking, as soon as I re-connect it to my computer it begins beeping and blinking.
2 Suggested Answers
  • 184 Answers
SOURCE: AC/DC ADAPTER MODEL ADP-90SB BB
http://cheaplaptopsforsale.org/buying-tips/laptop-ac-adapter-not-working-steps-to-resolve-the-problem/
Read the article above. It tells you how to solve this problem.
And if turned out your adapter was defective, the link below may be helpful for you.
http://www.chargerbuy.com/replacement-asus-ac-adapter-19v-4-74a-adp-90sb-bb.html
Posted on Dec 21, 2010
ASUS adapter for 501J series has a short in the cord. Am in need for a Model # ADP-65JH Input 100-240V Output 19V - 3.24A. What do I need to order. E-mail: krfecht@mac.com
You need a mains adapterthat has Input 100-240V Output 19V - 3.24A and the input plug that fits into the power socket of your laptop. It does not need to be from ASUS.
Google search the Internet for a suitable power adapter, make sure the output voltage is the same and the amps is 3.24 or higher.
Mar 11, 2011 | ASUS Televison & Video
The charger for my asus x5dc laptop won't work when plugged in. The power light on the charging unit now only flashes insted of being constant. Please help I need laptop for work tomorrow.
Get a new charger. They are pretty cheap. They are notorious for burning out. If that doesn't fix it then the motherboard is bad. But I'd assume the burned out charger.
Mar 06, 2011 | Computers & Internet
My adp-75sb ab power cord stopped working all of a sudden what happened? ive had it for about 3 years if that helps
Well, sometimes thing just die and usually a year or 2 is the average lifespan of a charger. Not to mention that there may not be any rips or tears but there could be internal damage or perhaps a manufacture defect of some sorts. More than likely it either died of age or because of consumer use. Your simple solution would be to get a new charger.
Try this link:
http://www.chargerbuy.com/replacement-delta-adp-75sbbb-75watt-ac-adapter-19v-3-95a.html
Feb 27, 2011 | Toshiba 65-Watt Global AC Adapter ADP-75SB...
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
Laptop won't power up dies in the middle of movie-won't power up
You would probably be better off buying a new notebook. Not sure how tecnologically advanced you are but it seems you already did the troubleshooting yourself. But i am very interested in the a/c adaptor output. If the led on the adaptor is green that just means that it is getting power from the wall.
What did you mean by fluid leaking out?
It could be the mobo (motherboard) or it could be the connections from the power to the machine. If you want to put a new mobo in I have to warn you that taking apart a laptop is VERY difficult and I do not recommend this unless you are a PRO. This is just about the only link i can find to buy a new board. If you google your laptop model you will find out you definately are not alone with this problem
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=1183
Please don't forget to rate my response and let me know if there is anything else I can help you with.
Jan 08, 2009 | Computers & Internet
When switch is turned on alarm sounds and there is no power
It could be a cmos battery boot it in bios and check for flagged components, if u do not find anything try it with another power supply as this could several different problems
Dec 18, 2008 | Powerline 200Watt DC to AC inverter...
Power supply for a 5500C
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Jul 02, 2008 | HP Scanjet 5500c Flatbed Scanner
Televison & Video Logo
1,107 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
David Payne
David Payne
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
