Question about Science & Laboratory
Cannot see slide image at all
Unable to see the slide when it is placed on the stage. appears to be as if the lens is covered but is not. the light comes on when facing away from the stage at an angle.
SOURCE: lens only comes half way out
I had a problem that may be related to yours. From time to time, whenever I opened the cover, the lens wouldn't work properly. It would make a grinding noise and then when I took pictures they would all come out out of focus. After much fiddling about, I eventually discovered that if I set ALL RESET to FALSE on the SETUP menu, it returned to normal. Possibly this could fix your problem. Otherwise maybe its a battery problem. My camera sometimes refuses to take pictures when the battery is low.
Posted on Nov 09, 2007
SOURCE: Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Posted on Mar 09, 2008
fcollingwood
  • 58 Answers
SOURCE: dark picture taking on stage
You need to run it with aperture priority, and have the aperture as wide open as possible (The lower the number the better). You've got the kit lens, which is a notoriously poor performer in low light conditions, you should consider getting one of the Sigma DG lenses.
The other alternative is to get as close up to the stage as possible, and use the smaller lens that would have come with the camera kit. It's a little faster.
Posted on Mar 21, 2008
  • 198 Answers
SOURCE: Adapter ring cover problem
Maybe the adapter ring release button is stuck after you pushed it in to release the cover. Try giving it a good flicking until you are sure it has popped out.
Posted on Mar 24, 2008
  • 479 Answers
SOURCE: turns off due to sliding lens cover
may need to replace the screws in the door or even tighten them up
Posted on Feb 18, 2009
Changing the brake light lamp/bulb
the plastic posts are guides /support they just slide into place attached to lens just slide/pull the lens off
Jun 18, 2017 | 1995 Toyota Corolla
My Sony DSC T7 camera lens problem, When I slide the cover of lens, its says that "Lens cover Closed". so I am unable to take picture. Please help me. Thanks Anil
Mr anil there seems to be a problem with the sensor linked to the lens guard. Try to move the lens cover a few times and try to open the cover as much as possible just to initiate the sensor. If this does not solve the problem then you have to show it to a mechanic.
Regards.
Jul 14, 2011 | Sony Cameras
Edu science 600x microscope: no instruction manual and I cannot see anything through the lens (only a blurred blue light). What must I do to be able to see something ? Thx
Well I have the instruction manual, but it is not too helpful. When I was a child I put fleas and ants on the slides, but I guess this microscope is different. Here is what my manual says.
How to make a prepared slide: If the given sample is not thin and transparent, it cannot be observed by the microscope as the light from the reflector or the light source does not pass through it. Fibers, pollen, wool, or salt can be observed easily and a cover glass is optional. Clear samples are stained first with a drop or 2 of methylene blue, Eosin or other dying solutions (not included).
1. TEMPORARY MOUNT: Wipe the slide and cover glass clean. Slice a thin sample with the micro-slicer (blade is very sharp...adult supervision). Pick up the sample with tweezers and put it on the center part of the glass slide. Put one drop of water on the sample using the needle that came with your kit.
2.PERMANENT MOUNT:Proceed as above, however, before covering the slide with the cover glass, add a few drops of gum media (not included, available at the store) or Canada balsam solution or transparent adhesive glue with a disecting needle to the slide. Push down on the cover glass with the tweezers to fix it in place and leave to dry for a day.
VIEWING LIVE BRINE SHRIMP:
1.Pour a small amout of brine shrimp eggs into the petri dish.
2.Add enough water so that the eggs are submerged and add just a dash of table salt.
3.Place the petri dish in a well lit area (under a lamp with a 60 watt bulb is good, for 24 hours).
4. When you see movement in the petri dish place it on your microscope stage, turn on the light and watch the brine shrimp in action.
Jan 08, 2011 | Edu-Science Edu Science Microscope 600X
I need to replace one of the red lens light covers
You need to take off the back to place the lamp on the lens.
Jun 04, 2010 | Frigidaire FEF336BC Electric Kitchen Range
How to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
You should replace the PCU if prints show any of the following symptoms.
  • Colors are missing, faint, or partially blurred.
  • Toner smears appear.
  • White or color rivers appear.
  • White or colored streaks appear
    1. Important: Switch off the device and disconnect it at the mains.
    2. Open the right side cover.
    3. Pull the green levers as shown to release the inner cover.
    4. Lift the inner cover upwards.
    5. Squeeze the green lever on the black PCU.
    6. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
    7. Place the new PCU on a flat surface.
    8. Peel off the tape from around the new PCU.
    9. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
    10. Rest the new PCU in the device as shown.
    1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
    2. Lower the inner cover.
    3. Push the two green levers as shown to secure the cover.
    4. Close the side cover.
    5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
    Please remember to rate all users who assist you for free :)
Aug 07, 2008 | Ricoh Aficio CL3500N Laser Printer
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
W580i problem
They have a really really tight cover,which slides down away from camera lens.
Mar 30, 2008 | Sony Ericsson W850i Cellular Phone
Cover open, unable to take a picture?
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
Open cover
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cover open
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Science & Laboratory Logo
67 people viewed this question
Top Science & Laboratory Experts
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
