Toshiba 3560 paper feed jam at first roller; paper stops.
  • 30 Answers
Hi,clean the first roller & check little piece of paper around first roller.finally replace first roller.
Posted on May 18, 2009
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
I cannot get the paper to feed from the tray instead of the manual
85% of paper feed problems are caused by worn. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper feed problems will go away
Thanks, Joe
Mar 09, 2011 | Brother HL-2070N Laser Printer
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
Frequent Paper Jams Toshiba 1310
Clean the paper feed rollers and the separator/transfer coronas.Check and clean the fuser rollers.
Aug 10, 2009 | Toshiba Office Equipment & Supplies
Toshiba estudio 200 keeps having false paper jams where are paper sensors located?
its not the paper sensors you need to get to its the feed rollers,which will be above the paper tray near either the left or right side of machine. clean those with glass cleaner. if they appear smooth in any way they should be replaced, keep old ones to compare. what you are referring to as false jams we in the copier world call the "ghost jams"
May 08, 2009 | Toshiba Estudio 200L Copier
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
106 people viewed this question
jasbo
jasbo
