Question about Polaroid Pmp110-4 4gb Mp3 Player Video Photo Music Movie
Polaroid pmp110-4 wont charge
I plugged it in to the compter and xbox and it wont charge, it only works inside the charge but when i unplug it it shuts off
3 Suggested Answers
  • 1779 Answers
SOURCE: 42" LCD Polaroid shut off and wont turn on.
Most likely defective capacitors in the power supply.
Posted on Dec 12, 2009
spr1949
  • 1182 Answers
SOURCE: Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Posted on Aug 23, 2012
Connecting an xbox controller
Do you have charged bat packs or fresh bats. Have you synced both the controller and the xbox together? Unplug the unit for a min. and check all connections if wired. plug in and try to sync again, Push the little buttons on the front of the controller and the on on the unit at the same time and see if the lights do the circle thing. That will usually work for me.
Aug 12, 2014 | Microsoft Xbox 360 Controller
POLARIOD KIDZ TABLET 2WONT CHARGE
Make sure the tiny circuit board inside the charge port is not bent, otherwise the charger plug will not get inserted properly and get connected.
May 24, 2014 | Polaroid Tablets & eReaders
My xbox 360 controller wont turn on and i use the charge and play batteries and when you plug it in it works but when you unplug it does not work.
From time to time the actual charging capacity of the play and charge battery will fizzle out as will regular rechargeable batteries.
If you know someone else with a play and charge ask to use theirs on yours and see if it charges and holds charge when you unplug it.
If it does then you need to purchase a new play and charge, if it doesn't the connection to the battery pack is damaged and more then likely you will need to buy a new controller. Or just keep it wired.
Hope this helps.
-- JD
Jan 12, 2011 | Microsoft Xbox 360 Wireless Controller
Plugged in to compter to sync and now it wont come on at all
http://support.apple.com/kb/ht1320
Sorry, Go to this link just follow the instruction's
Apr 14, 2010 | Apple iPod nano
Compter and xbox will not work together on the same router.
Did you check this?
http://www.home-network-help.com/xbox-network.html
Apr 03, 2010 | D-Link AirPlus DI-524 Wireless Router
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
http://www.techsick.com/shop/images/P/xb360-controller-charger-36.jpg
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
Sep 24, 2009 | Microsoft Xbox 360 Wireless Controller
My notebook will not charge. It stays on battery
pull the battery out and unplug the power changer hold the enter key for one full minute then install battery see what charge amount says if half way drain it till compter shuts off then charge, if it does not fix the problem the battery is dead.Rate if this was helpful.
Aug 14, 2009 | Compaq 2710p Tablet PC - Intel Centrino...
Syncing dont work!!!!
Sounds like the sync button is probably stuck. You should tap it a few times with something pokey like a pin and see if that helps, if not the contact inside broke off and the easiest thing would be to replace it.
Jan 29, 2009 | Microsoft Xbox 360 Controller
Polaroid Pmp110-4 4gb Mp3 Player Video Photo Music Movie Logo
48 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Owen Barnes
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
