Question about MICHLEY TIVAX Michley MiTraveler 7 inch Capacitive Tablet w/ Android 4.0 with Wi-Fi Black
System UI has stoped
Just got it today for christmas when i noticed power doent work. Only powers on with charger. Then when trying to put music on the tablet from my pc the tablet began to. Start the system UI has stopped working. Now i cant do absolutely nothing. . I cant even leave of the screen. Cant restart or shut down neither buttons work. Dont know what to do. Going. To let it die until i can get some help then power off. Then attempt to power it up with charger... please help me!!!
Bought my grandson a Fire he 8 for Christmas, I plugged it in to charge last night and it did not charge. Tried a different charger today, still didn't take a charge. Any suggestions?
I don't know if it's your battery or charger, but Amazon is very good
with customer support. Have you called their customer support?
The number is: 866-216 1072
Jan 21, 2017 | Amazon Kindle Fire HD
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
My ZEKI android tablet keeps saying that unfortunately system UI has stopped working what do i do?
You can try pulling the battery then reinstall it and restart the unit. If that doesn't clear the problem go to settings, and then applications and look for UI and clear the cache and data. If that fails you can try to do a factory reset.
Nov 09, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
How do i fix meep tablet when it says UI has stopped working and meephome has stoped working and it doesnt turn on
For any 'Has Stopped' messages, you'll need to run a factory reset from the Settings menu then re-establish Wifi and recover content in the Meep Store. If it won't power on at all, that is then a hardware issue and would need to go through the OSI call center: 800-853-8883.
Apr 08, 2014 | FUHU nabi Jr. 5" Capacitive Touch Android...
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Received in the mail today 3 of the 7" Genesis Prime tablets for my kids. One of the tablets is saying "Unfortunately the UI stopped & Unfortunately the Wizard has stopped" I didn't have any problems...
UI means "user interface." It likely means "GUI"--"graphical user interface"--pretty pictures on a screen upon which one points and clicks. Thus, you can't use the touchscreen. Try a "soft" reset. If that's ineffective, try a hard reset--often called something like "Restore Factory Settings." If you find the manual, physically--or online via a mfr. site PDF, follow it's procedure for those. Otherwise, try pressing the power on button for 20 seconds or so--see if the screen then offers hard reset. Press "Yes" or otherwise assent.
Dec 19, 2013 | Tablets & eReaders
ViewSonic ViewPad 10e Wont Turn On
It may be frozen. Try holding the power button down for 10-15 seconds.
Dec 12, 2012 | Tablets & eReaders
I received a Literati Reader for Christmas. It has worked fine but now I can't even turn it on. On 8-30-2011 it just goes to this grey and black screen and I called 1*800*481*7983 I started calling...
Can you please unplug it first the power cable then press and hold the power button for at least 30 seconds, after doing that, plug the power cable to the outlet then press and the power button until the device will turn on, just press and hold the power button.
Thanks.
Sep 09, 2011 | Sharper Image Literati Reader 16375680042...
MICHLEY TIVAX Michley MiTraveler 7 inch Capacitive Tablet w/ Android 4.0 with Wi-Fi Black Logo
21 people viewed this question
Top MICHLEY TIVAX Tablets & eReaders Experts
Are you a MICHLEY TIVAX Tablet and eReader Expert? Answer questions, earn points and help others
