Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice at bottom of side by side refrigerator
Water accumulates at the bottom of refrigerator side and turns into ice. This is a side by side unit so the drain from the freezer should have nothing to do from making the way to the other side. I think the problem is on the refer side but I cannot figure where the water is coming from. Help!
  • GE Master
  • 842 Answers
You are looking for the water source, two possible places to look. Look around the water filter and the glass shelves for water, also check the water tank behind the crispers, as I have seen them crack in the past. Good luck, hit me up if you need more information.
Posted on Dec 26, 2013
  • Andrew Jackson Apr 02, 2014
    If the amount of water is too much to be condensation then it is safe to conclude that the source of the leak is something else. If you are satisfied that it is too much to be anything but a leak, then by tracing the supply lines in the compartment is a good source to suspect. Do this, remember you are trying to solve a problem so, some work will be necessary. Get in there with a cloth and dry it out good. Then, take some paper towels and wrap them around the possible problem. Since you have the problem, you probaly know how long it takes for the water to show up. Deductively reasoning, the towel that has the water soaked into it, is your leak. Hope this helps, when you discover the leak and if it is unclear what you need to fix it, repost for a possible solution. Andrew
    Don't start spending money on anything until you know exactly what is needed. Don't you just despise the kind of company that doesn't do anything to support their customer. Might as well be living in a third world country. Industrialized Nation, Yeah right.
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
  • 10865 Answers
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 15, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Water accumulates in the freezer tray turning to ice & flows to the floor if ice not removed in time.
there is a drain tube along the back inside of freezer side that clogs up with ice use hot water to melt ,and you may have to remove rear cover in back to remove the drain tube on right side to clear it .
Mar 16, 2015 | Whirlpool GB2FHDXWS Bottom Freezer...
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Joe
Sep 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice accumulation in the bottom of the freezer. There is no indication of water leaking from the ice maker or the door.
check door seals are touching all round,then manually defrost unit and clean all drains/vents
Mar 31, 2010 | Maytag MZD2766GES Side by Side...
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Freezer is icing up. Unit is about 2 yrs old
You need to check out the back of the freezer. At the current status, it may be locked with ice. Have it defrosted or just have it melted away. Clean the coils and the entire unit. Either the drains were blocked by food debris or dirt causing water to accumulate and ice to form or the thermistor has been iced or is faulty or too much ice accumulated in the unit's coils.
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
